right front rattles
Old Feb 20, 2005 | 02:54 PM
Huffs_91_RS's Avatar
Car: 84 Z28
Engine: 383
Axle/Gears: 342 Posi
right front rattles
When going around corners or turning the wheel some times it makes a rattlen noise. Have fairly new struts, bearings, & ball joints. The noise is just on the passenger side. Any suggestions!
Old Feb 20, 2005 | 03:10 PM
Vader's Avatar
Even though the noise is only apparent on the RH side, does it happen when you turn in either direction?
Old Feb 21, 2005 | 10:13 PM
Car: 84 Z28
Engine: 383
It does ever know and then. It really dont matter which way I'm turning the wheel. I do know that it is comeing from the right side. I've been told that it could be one of the bushings.
Old Feb 22, 2005 | 12:20 PM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
bushing, or strut mount may be bad, did you get them done recently also?
Old Feb 22, 2005 | 12:26 PM
Car: 84 Z28
Engine: 383
right front
Yeah. I got the struts when I did the bearings and ball joints. The bushings is what most people say that it could be.
Old Feb 22, 2005 | 01:02 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Does it sound like coins in your pocket? If it does, it's sway bar end links.
If it sounds more liks a metal plate rattling, almost a clattering sort of sound, it's your brake pads.
Old Feb 22, 2005 | 01:11 PM
Car: 84 Z28
Engine: 383
right front
It sounds sort of a clang. The brakes just got put on about a month and a half ago. The sound was there before and after that. It just makes the sound sometimes, not ever time I'm driven.
xxx3man`
Sep 23, 2015 10:37 PM
mantaguy
Sep 1, 2015 08:39 PM
aaron7
Aug 26, 2015 09:45 AM
mustangman65_79
Aug 8, 2015 12:07 PM
