Is this a good combo for high 12's?
Old Jul 2, 2001 | 12:38 AM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
Stock L98 bottom end w/ AFR 190 heads, Edelbrock manifold base w/ LPE Super ram plenum and runners (The Edelbrock base is over $100 cheaper than the Accel/LPE manifold and they are virtually identical), LPE 219/219 cam (specs=Dur @.050" 219/219; lift w/ 1.6 roller rockers .560"/.560"; CL 112), and 3.45 gears w/ an appropriate stall converter on a 700R4. Of course I have a full high-po exhaust and other mods to support these changes.
Old Jul 2, 2001 | 07:04 AM
Biochem's Avatar
Car: 2002 SOM z28
There was a guy ZBRA running a very similar setup to that... I think he had a problem with the Superram and/or the 219 cam.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Jul 3, 2001 | 09:13 AM
BuckeyeROC's Avatar
No one else has or has seen someone with this setup?
Old Jul 3, 2001 | 11:13 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Well, there is a guy on corvetteforum with the same setup on his stock 85 shortblock and he's running high 11s.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Old Jul 3, 2001 | 11:36 AM
BuckeyeROC's Avatar
Wow! High 11's is more than I expected. I'd be thrilled if I got anywhere near the 11's. I do plan on taking the car to CarPro in Michigan to have them dyno tune the combo after it's installed.
Old Jul 3, 2001 | 06:01 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Corvettes hook up really well compared to our cars. Realistically, IMO mid to low 12s with our cars can be attained with good traction.
See this thread too:
http://www.corvetteforum.cc/ubb/Foru...ML/009125.html
[This message has been edited by IROCZZ3 (edited July 03, 2001).]
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
Fronzizzle
Aug 19, 2015 01:36 PM
