ZZ4 cam and 300 hp heads on a 305?
Old Feb 22, 2005 | 11:00 PM
twisselman1968's Avatar
Car: 88 Trans Am
Engine: .060 over 350 zz4 cam vortec heads
Transmission: 5 speed
Axle/Gears: 3.73posi broke/2.73 open till fixed
I've got the 305 out of my 89 formula and I'm going to put it in my S-10 its got 184,000 miles on it and I've got a set of 300 horse heads casting# 14096217 that are brand new and I've got a zz4 cam has anyone did anything like this with there 305 and has anyone skatered any of there 305's I beat mine prety good in my firebird and it took it well good oil presure and good cylinder presure I'm also woundering about the compression I'm going to give up going to 64 cc heads anyone think I should have them milled a bit or I'm I already going to be pushing me valve to piston clearance with .474/.501 lift any help please
Old Feb 22, 2005 | 11:24 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
i'm unfamiliar with the heads, but assuming they can handle the lift, you're looking around your goal.
Old Feb 23, 2005 | 12:36 AM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Check my sig. Thats with TBI, so a carb with that setup should do well. I'd say my setup is just under 300 at the crank so with a ZZ4 cam you should be there.
Old Feb 23, 2005 | 02:35 AM
84 Restore's Avatar
Car: 1984 Z28 camaro HO Gun metal Gray
Engine: 305,L69 H.O. rebuilt
The 305 is low on HP but it is a tank when it comes to stress. It can take a whole lot before it gives up. power that puppy up and have fun.
Old Feb 23, 2005 | 08:20 AM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I'm not sure what pistons your engine has, flat or dished, so it's impossible to do a calculation on the CR.
But I'd suggest finding out for sure what the CR is with those heads and what your V/P clearance is as well, before you bolt them on.
Milling the heads could be the answer.
Another possibility might be to sell or trade the heads to someone who has some 305 heads with the smaller chamber.
64cc is a good chamber vol for a HP 350 and your heads could be the solution to someone elses problem.
Old Feb 23, 2005 | 10:13 AM
Car: 88 Trans Am
My motor has flat top 4 valve relief pistons I'm going to run these head because they have awsome ports and good springs on them I'll just take the cut in comp and live with it if its weak I'll put a 125 shot on it I've got and flog it
Old Feb 23, 2005 | 01:54 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
I think with those 300 horse heads you are better off with a 3/4 race cam
Old Feb 23, 2005 | 03:17 PM
92heritageRS's Avatar
Car: 06 Trailblazer SS
Engine: 6.0 LS2
Axle/Gears: 4.10
what is a 3/4 race cam? I have heard that before.
Old Feb 23, 2005 | 04:54 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
lol good question, they are like 300 horse heads
Old Feb 23, 2005 | 05:18 PM
Engine: 6.0 LS2
Axle/Gears: 4.10
OH ok. One of those things huh. Thats funny!
Old Feb 23, 2005 | 06:20 PM
Car: '85 IROC
Engine: LB9
For anyone who's ever wondered
Believe it or not, this is an actual, certifiable 3/4 race cam
You can go out and buy one yourself today
270-100172
Energizer 3/4 Race Hydraulic Flat Tappet Camshaft & Lifter Kit
Lift: .450''/.450''
Duration: 274°/274°
RPM Range: 2200-5200
ROUGH IDLE, MODERATE PERFORMANCE USAGE, GOOD LOW AND MID-RANGE TORQUE AND HP, MILD BRACKET RACING, AUTO TRANS W/2500+ CONVERTER, 2600-3000 CRUISE RPM, 8.75 TO 10.0 COMPRESSION RATIO ADVISED.
Grind Number: 274 H06
Operating Range: 2200-5200 RPM
Duration Advertised: 274° Intake / 274° Exhaust
Duration @ .050'' Lift: 218° Intake / 218° Exhaust
Valve Lift w/1.5 Rockers: .450'' Intake / .450'' Exhaust
Lobe Separation Angle: 106°
Max Lift Angle: 102° ATDC Intake / 110° BTDC Exhaust
Open/Close @.050'' Cam Lift: Intake - 7° BTDC (opens) / 31° ABDC (closes)
Exhaust - 39° BBDC (opens) / (1°) BTDC (closes)
Old Feb 23, 2005 | 07:48 PM
1987formula's Avatar
Car: 1987 formula
Engine: 406 sbc
If you don't mill the heads with the cam you have you will be lucky if it has a170 horse shave the heads so there around 55cc install the cam and a 2800 stall all will be good.
Old Feb 23, 2005 | 11:05 PM
Car: 88 Trans Am
I went to buy head gaskets today and the computer at autozone said I needed new head bolts what kind of crap is this there not torque to yield this motor isn't a ls1 or noyhin anybody else been told this..I'm just going to use the old bolts like I have with every othersmall block I've ever had the heads off of...and the heads I'm puting on it are from pace parts and are the 285/300 horse crate motor heads and have 180cc intake runners and are very simular to the phase II head but have exhaust crossovers.
Old Feb 24, 2005 | 11:00 AM
Car: 89 Camaro RS
Engine: 305 TBI
They say that once head bolts have been torqued once they stretch enough that they could cause head gasket leaks. But you could probably get buy with the old ones.
Old Feb 24, 2005 | 11:58 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Post the casting numbers.
All the rest of this "300 HP" this and "simular [sic] to Phase II" that and "180cc" something else, is just useless drivel. Casting numbers tell all. Nothing else is worth the bandwidth it takes to post it.
How much you want to bet that they're Hecho En Mexico 993s? In which case, they're 76cc chambers, so your CR will end up at about 7:1 by putting them on a 305.
Old Feb 24, 2005 | 12:02 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
14096217 are the castings. Listed in the first post.
Old Feb 24, 2005 | 09:26 PM
Car: 88 Trans Am
my 217's are 64 cc chamber and I'm havin .040 shaved of them and runin the thinest gaskets I could find and my motor has flat tops and I'm puttin the cam in 2 degrees advanced to keep cylinder presure up this isn't my first rodeo I've been buildin motors since I was thirteen I'm almost 23 now I was just wondering if anyone had did anything like this I've never built a 305 I've built 283's two DZ302's a bunch of 355's 383's a handful of 406's anything from almost stock all the way to a 18 degree brodix headed 385 that has 14.6 to 1 over .700 lift and loves to eat valve springs (and a mustang or civic every now and then) I just wanted to know how many of you guys have acually messed around with 305 and if there any fun I'm just going to put it together and flog the **** out of it if it blows it blows I just hope it dosen't ruin my cam but if it does it does it was only a hundred bucks I didn't want to sound cocky but I proubly did thats just me sorry just wanted to let you know I wasn't some dumb kid working on his first motor I know i won't make 300 horse I'm realalistic I'll be happy if it makes 200 and I get to flog it for a while my firebird has an 96 lt1 in it now and its 300 horses maybe a little more maybe a little less but it feels awsome I just want to put this motor in my s-10 and it sound good but still be driveable and not be a tire fryer
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
italiano67
Dec 11, 2016 09:21 AM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
