steering columns ( what years can i swap with mine?)
Old Jul 5, 2001 | 07:29 PM
silvermelon's Avatar
the steering column in my 86 z28 auto is now officially dead. and of course the junk yards dont have any from an 86'. what years steering columns will be a no-hassle swap.
thanks!!
Old Jul 5, 2001 | 10:04 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
As far as I know, those from an 84-newer will swap directly as long as both have the same wiper/cruise options; the 82-83 will bolt in, but will require some switching of wires to the wiper switch.
Pete
Pete's Place
HiOutput Tech Page
83 SC
originally a V6...now
210+k mile LG4/5-speed
14.935@94.14
Old Jul 7, 2001 | 11:59 AM
John'89L98's Avatar
You might even be able to swap up to an '89. The tilt steering in my '89 IROC was really loose, so I threw the column out of my '86 in there until I could get the '89 column apart to tighten. It was quick and easy. Only thing was that I couldn't use the VATS ignition since it seems the igntion cylinder hole (whatever) doesn't have a place for the VATS wire to run. But other than that, the column matched up perfectly - wires and all. Good luck. - John '89 L98
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Bull86
Aug 10, 2015 05:43 PM
