valve lash on hydroylic lifters
Old Feb 27, 2005 | 10:57 AM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
Is this method of setting the lash/preload good?:
I was gonna do the EO/IC method, but can't you just watch the intake valve open, then the exhast valve, then as you see the exhaust valve close, you turn the crank a little more and you should be on base circle for both valves. So you can now 0 lash the rockers on both calves for that cylinder, right? then you turn about 1/4-1/2 turn. thanks -Justin
Old Feb 27, 2005 | 01:35 PM
Vader's Avatar
However you determine that you're on the base circle is up to you. You can follow the "opposite firing order" method, or watch the valves and spin the crank a bit furhter to assure that you're down there.
As for preload, I personally don't like to go more than ½ turn after zero lash specifically to avoid potential problems from lifter pump-up at higher RPM and oil pressures.
Old Feb 27, 2005 | 05:30 PM
Car: 1987 GTA
okay, it's done, i used the EO/IC method instead, very easy to do, except, that i hope i was turning the motor in the right direction, otherwise, you'd adjust during overlap, but i think i did. looking at the front of the block, i turned it clockwise...the oposite valve's lifter was all the way down,. so i guess it was on base circle. ( i hope). anyway, anyone know the intake manifold torue sequence? thanks.
Old Feb 27, 2005 | 06:59 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Forget that...I always adjust mine with the engine running. I never go more than a 1/4 turn past zero lash too.
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
dimented24x7
Sep 6, 2015 03:51 PM
