Its Cold Help!
Old Mar 1, 2005 | 08:42 AM
liteumup387's Avatar
Car: 1982
Transmission: 350
Its Cold Help!
Hey i have a problem. When i was working on my car i accidently broke the blowermoter case ( the part the bolts to the fire wall then the blower motor bolts into it) and now i dont have heat and i cant seem to find it anyware, no auto part store carries it and i cant seem to find it on the internet. I live in chicago and most of the junkyards are closed but when i warms up i wont need heat so i want to find the part as soon as possible. Is anyone selling the blower motor case or does anyone know ware i can get the part i need.
Old Mar 1, 2005 | 10:02 AM
gnatshop's Avatar
Car: '94 GMC Sonoma
Engine: 406 sd TPI
How about good old duct tape to hold it back together enough to keep the warm air in?
Your could also use a soldering iron (better with one of those wide flat tips) to do a little country boy plastic welding.
David
Old Mar 1, 2005 | 11:44 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Im sure someone has an old A/C heaterbox theyd part with on the classifieds. Try there. Also, the a/c heaterbox is made of fiberglass/resin so if your good at working with fiberglass, you could possibly repair it. Probably easier just to get a new one, though.
Spyder_TheGamer
Oct 2, 2015 12:25 PM
ramicio
Sep 28, 2015 01:18 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
