rear end/wheels/spacers question.
Old Jul 9, 2001 | 12:58 PM
91FireChicken's Avatar
Car: 91 Firebird
Transmission: A4
I didn't know whether to post this in body, drivetrain, or suspension, so I picked this forum..
I'm going to get some 4th gen wheels for my car - http://www.slponline.com/view_produc...&SHOWEMAIL=Off ... I know I'd need spacers for them, which will cost me somewhere around $300 for all 4.. I was wondering if I got a 4th gen rear end if I'd still need spacers on the back, or if that'll be enough to make them look normal..
also, for spacers, am I just looking at about $150 for a pair? or is there anywhere cheaper?
Old Jul 9, 2001 | 01:10 PM
leirch's Avatar
I have a 4th gen Z28 rear in my car, I have those Bird wheels also. Check out my webpage for pictures also. You only need spacers on the front if you get the 4th gen rear.
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 SR Cam, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Jul 9, 2001 | 01:11 PM
Car: 91 Firebird
Transmission: A4
awesome. thanks. hehe
Old Jul 9, 2001 | 01:20 PM
Car: 91 Firebird
Transmission: A4
now, with that out of the way.. where's a good place to get a 4th gen rear end? preferably posi with disc brakes, used, not new, unless it's a real cheap new one..
RedLeader289
Jan 22, 2016 03:05 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Bryan F
Aug 18, 2015 02:28 PM
wruiz
Aug 13, 2015 09:07 PM
jahblah
Aug 12, 2015 05:54 PM
