MAF calibration
Old Mar 3, 2005 | 02:10 AM
davcamaro's Avatar
Car: 1985 IROC
MAF calibration
I just changed out my MAF because it was totally fried and ever since I put the new one in, I lost power in general and a lot at 3000 rpm. I heard that is a calibration broblem. is it and how can I fix it?
Old Mar 3, 2005 | 02:18 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Custom porgramming. If you didn't need it before the maf swap then you don't need it now. Your new maf may be bad or you are due for a tuenup.
Old Mar 3, 2005 | 10:14 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: MAF calibration
Did you disconnect the battery for a few minutes to erase what the ECM has learned since the last time the batery was disconnected? (restores factory defaults)
Old Mar 3, 2005 | 01:02 PM
davcamaro's Avatar
Car: 1985 IROC
re:battery
I'll try cutting power to the ecm, maybe that is my problem, I'll keep you posted, thanks
Old Mar 3, 2005 | 02:36 PM
Cooper's Avatar
Car: '89 GTA
Axle/Gears: 3.45
also make sure you have the right maf sensor, I noticed you have an '85 and they are a bastard year. They all look the same and I think they all have the same plug but there was one for '85, one for '86-'87 and one for '88-'89 iirc.
Old Mar 3, 2005 | 02:45 PM
Cooper's Avatar
Car: '89 GTA
Axle/Gears: 3.45
Did a little digging: (gmpart #'s)
'85 - #14081243
'86 - '87 #14094712
'88 - '89 #10055877
Old Mar 3, 2005 | 06:33 PM
davcamaro's Avatar
Car: 1985 IROC
type of MAF
I have a bosche MAF (from napa), but I am not sure right now what the part number is, I'll check it and get back to you
Old Mar 3, 2005 | 06:45 PM
Engine: SBC, LS-x
You will have to do a x-ref. GM part #'s will not match Bosh part #'s.
Old Mar 3, 2005 | 11:44 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
The 85' has a separate MAF control module that piggy backs on the ECM. On later models the MAF control was integrated into the ECM.
Old Mar 4, 2005 | 03:43 AM
davcamaro's Avatar
Car: 1985 IROC
I unplugged the battery for a few minutes and ran it. it seemed reasonable fine, but the real test will be running it in the day. I am not sure if runns like it used to though, it has been a while since I changed the MAF. according to the napa website, the part number for the 85 GM MAF is the same thing as the one I have, just a different company. does heat and/or daylight have anything to do with the MAF?
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
