Is one bank running hotter?
Old Mar 5, 2005 | 11:42 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Ok, The spark plugs on the driver side bank were grayish. They were all pretty old, too. But they didnt really show any signs of engine trouble. But I replaced the ones on the passenger side today and they were all black with carbon. Not a lot of it, but some. They had oil on the threads, and the rearmost one was a little wet, though I havent gotten around to replacing the seals on that side yet.
My dad said the driver side bank must be running hotter, and that's why the plugs on it are gray when the passenger ones are all black.
What gives?
Old Mar 6, 2005 | 12:20 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
drain your oil- does it look like chocolate milk?
Old Mar 6, 2005 | 12:29 AM
305q_ta86's Avatar
Transmission: 5 spd
Nope, looked fine.....why?
Old Mar 6, 2005 | 12:32 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Just making sure you don't have a blown head gasket... how has your car been running lately?
Old Mar 6, 2005 | 09:09 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Look at the casting numbers of the 2 heads. You might have 2 completely different heads.
Happens more often than you might think.
Non-technical customer to parts store: "You got heads for a 305?"
Parts store guy: "yeah"
Customer: "How much"
Parts guy: "[fill in the blank]"
Customer: "Guy down the street has them for [fill in the blank minus $50] what will you sell them to me for?"
Parts store guy: "Well I got a couple you can have for [fill in the blank minus $60]"
Customer: "Sold!!!"
And that's how you end up with 2 different heads.... both of them crappy castings, at least one probably with something irrepairably wrong with it, but not so bad that it won't run. Or, 2 mismatched heads where the mate to each one was cracked or something, and he wants to get rid of them.
You might find you have one 76cc smogger 165 HP 350 head like a 624 on one side, and a 60cc 305 2-barrel head like a 450 on the other. Both pieces of crap, but entirely different.
Old Mar 6, 2005 | 09:39 AM
305q_ta86's Avatar
Transmission: 5 spd
Ok, about the oil, the engine has been running perfectly fine lately.
As for mismatched heads, I know for certain the driver side one is a 416, because I looked. I will check the other head when I install my new rockers and springs on that side.
If not, I will be in the market for a set of worked 416's...
Old Mar 6, 2005 | 01:26 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I had a badly leaking intake manifold gasket on one side that did that. I replaced the gaskets and it was fine after that.
Old Mar 6, 2005 | 01:43 PM
305q_ta86's Avatar
Transmission: 5 spd
Uh, ok, so which is the bad side?
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
gta90
Sep 15, 2015 04:00 PM
perZ
Aug 21, 2015 05:51 PM
