which cam? xe-256 or xe-262
Old Mar 6, 2005 | 05:17 PM
V6camaroman's Avatar
im looking at some comp cams for my 85 z28 thats got the 305 tpi motor. i got it all apart and i want to some insite on which cam i should go with. should i get the xe256 or the xe-262 grind. the 256 looks like a real nice streetable cam but the 262 has a little more lift and a little more duration. but to compensate for the duration it has a 114 lobe seperation. whereas the 256 only has a 112.? any ideas. i know a few 305 people have run the 256 grind.
Old Mar 6, 2005 | 06:20 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I would go with the xe 262 cam since you have exhaust upgrades planned. Either cam will be streetable. I have the HOT cam and it is VERY streetable. It barely is noticable when the engine is warm.
Old Mar 6, 2005 | 07:51 PM
are there any people here who have the xe-262 in their 305 tpi motor. i have seen some people run the 256 in their carbed 305's but never in the tpi
Old Mar 6, 2005 | 11:24 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
I am running the XE256 in my 350 and I love it. This cam combined with the good low lift numbers of my 416 heads makes great torque and its super streetable. Both of these cams are very streetable. Also I think all of the XE cams have 110 LSA. If you plan on upgrading your gears or you at least have 3.23's I would say go with the XE262 but if you plan on running highway gears go with the XE256. good luck.
Old Mar 7, 2005 | 01:08 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Not much difference in torque between the 256 and 262. Heck my XE274H in a carbed 305 still had all sorts of low end. The 256 is so mild that a buddy and I stuck one in his 305 tbi and it ran fine on the stock chip. I would go with he 262 as it should run great. I would not even bother opening up the engine to do the 256 cam. Are you still running mass air?
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
