oil pressure sender/switch?
Old Mar 7, 2005 | 09:23 AM
The Shadow's Avatar
Car: 1989 Camaro RS
Engine: 305 V8 TBI
I have an 89 TBI RS Camaro. My oil pressure guage does not work. There is a sensor or sender on either side of the car that contols something for the oil. Which is the one above the oil filter? What is the name of the one with one wire that is just above the starter?
Old Mar 7, 2005 | 12:46 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
I think the one above the starter would be the knock sensor. Oil sender is always next to the oil filter.
Old Mar 7, 2005 | 12:48 PM
The Shadow's Avatar
Car: 1989 Camaro RS
Engine: 305 V8 TBI
thanks....i was just thinking about trying to find out where the knock sensor was
Old Mar 7, 2005 | 01:34 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
There's alot of confusion about these sensor locations.
The knock sensor is in front of the starter in the center of the block just above the oil pan lip.
The sensor above the starter on the cylinder head between The #6 & #8 spark plugs is the High Temperature Fan switch. The other one on the driver's side head is the coolant temperature gauge sensor, it's dedicated to the temperature gauge, and has no connection to the ECM.
Both the Knock and Fan switch have Identical connectors so don't get them confused.
If you have a one-wire sensor to the left of the distributor behind cyl #7 it's the oil sending sensor.
If the sensor at the oil filter has two-wires it's the Fuel pump switch (switched by oil pressure.) If it's a 3-wire then it a dual sensor for the Fuel pump switch and the oil pressure guage.
The 1991 and later models combine the oil sending sensor, and the Fuel pump/oil pressure switch into one, and is located at the oil filter.
Old Mar 11, 2005 | 12:57 PM
luvmy64's Avatar
Not trying to hijack your post, but does anyone know the colors of the wires going to the knock sensor and high temp fan switch? My connectors are broken off (motor swap). I think ive got the white connected to the knock sensor and the black to the fan switch. Anyone? (89 rs was 305 now 350, yes i have the 350 knock sensor)
Old Mar 11, 2005 | 01:01 PM
anondude13's Avatar
I'm almost 100% certain it was 1989 and later cars that were equipped with this setup, I know mine is. Therefore, I would recommend replacing the sender over the oil filter.
Old Mar 12, 2005 | 03:02 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
If there's no sensor behind the driver's side head, then the oil guage and pressure switch are one sensor located over the oil filter.
I have two sensors in the two locations I mentioned. The oil sender is a single tan wire, anf the pressure switch has a tan/wht & an org.
On my 88' the knock wire is white, and the fan temp switch wire is gray.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
