Help, Installed Electric Fan, What's Wrong.
Old Jul 9, 2001 | 05:16 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
OK, here's my setup I have a Griffin aluminum radiator with a 160* stat, I had a belt driven fan on there and it wouldn't run hot unless in traffic in 100* weather, but the car usually runs about 170*.
I installed a Perma Cool 2400 cfm fan to free up some horsepower. I start the car and let it get to 210* and turned the fan on, it never dropped below 210* and started to rise a little, so I just turned the car off. Any ideas as to why this fan isn't working.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
3:73 Richmond Gears and 3" Exhaust
"There is nothing more addicting than speed"
Old Jul 9, 2001 | 05:28 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Is the fan a puller or a pusher??ANother thing I can think of is the polarity
Daz
Old Jul 9, 2001 | 08:44 PM
Car: 99 Formula
Axle/Gears: 342
it can be both, I have it set up for puller, it's only a 12" fan though, I think that's the problem
'86 IROC
GM GOODWRENCH 350
FLOWMASTER, NO CAT
KN AIRFILTER
160* Stat
2:73 GEARS
B&M Megashifter
Old Jul 9, 2001 | 09:02 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Two reasons, first it takes anywhere from 4000-4800 CFM to cool a modded small block. Second, the Perma-cool fans are junk and do not even come with a shroud. Also you only used a 12" fan? Why not a 16" or even two 12" fans?
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Jul 9, 2001 | 11:01 PM
Car: 99 Formula
Axle/Gears: 342
Well my brother had it laying around, and I was hoping that it would work.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER, NO CAT
KN AIRFILTER
160* Stat
2:73 GEARS
B&M Megashifter
Old Jul 9, 2001 | 11:30 PM
Guest
Guest
Posts: n/a
One 12" fan aint gonna do it.
FYI the factory single fan is like 16 or 17" and is marginal IMO. Get another fan is my suggestion.
Old Jul 10, 2001 | 09:19 AM
Grand Prix's Avatar
The perma-cool fan also moves alot of air compared to the stock fan. I am not real happy with the lack of a shroud, but I guess you can't win them all. Verify the air is actually moving the direction you want it. More than once I followed the directions for setting the direction of airflow through a fan and have had problems. Ten minutes later when the engine doesn't want to cool you stick your hand in front of it and feel the air coming out the front of the car. Whooops, reverse leads and everything gets better. Maybe the fan was wired wrong, maybe the instructions were crap.
In the end you still may need dual fans. You are only pushing air through a 12" circle of the radiator. Even if the air is moving fast that still may not be sufficient. The only other thing I can think of is to leave the stock shround in place. That might force a small draft to pull air through the radiator other than where the fan is.
Old Jul 12, 2001 | 12:36 AM
gwman's Avatar
Perma Cool fans are junk. I had one 16" fan rated at 2900CMF and one 10" rated at 1250CMF and the single 16" fan worked better than the 2 Perma-Cools. Do yourself a favor and throw that fan in the trash. I did with mine.
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
Cameeeero
Aug 20, 2015 03:06 AM
86IROC112
Aug 17, 2015 02:00 PM
Firebird sweden
Aug 16, 2015 05:02 PM
