Vehicle Speed Sensor
Old Mar 9, 2005 | 10:10 AM
gray20's Avatar
Anybody have any idea how much it would be to put a vehicle speed sensor in a third gen camaro, specifically 1990 iroc, manual trans?
Old Mar 9, 2005 | 10:31 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Ummm.... 6 lbs?
No..... 14"?
Seriously.... it's easy. Beyond easy actually. One small bolt with a 10mm head holds it in. It takes longer to pick the car up off the ground and set it back down than to do the work.
A better place to start would be, why are you wanting to do that in the first place? They don't often just go bad.
Old Mar 9, 2005 | 10:36 AM
gray20's Avatar
Well I'm lookin at a seller's camaro and for whatever reason, he does not have a VSS in it, and so I was wondering what the price of that would be to do it if I bought this person's car. I was just worried that you'd have to take apart the trans mission to put the VSS in. Thanks
Tom
Old Mar 9, 2005 | 11:03 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No, it's real easy. If you know how to change oil, it's just about on the same level of difficulty as that; except probably not as messy.
If it "doesn't have one in it", there'd be a giant hole in the side of the transmission, gushing fluid. That doesn't sound right.
Old Mar 9, 2005 | 11:05 AM
gray20's Avatar
This is how he described it "the trans is a road race trans with no speed sensor. " *shrugs* I knew cars had to have a mechanism like this but before now I never knew that this was the specific device so I don't know much about it as you can tell.
Tom
Old Mar 9, 2005 | 11:17 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Maybe there's a plug in the hole or something.... I can't see it real clearly at my angle to know exactly what he did, though. T-5s all have that hole, if they fit one of these cars. It's the same hole as for a cable drive for a cable speedo.
In any case, the VSS itself bolts right in, very easy.
Old Mar 9, 2005 | 11:20 AM
gray20's Avatar
Thanks for the help. One last question, do you have to do any tuning once you put it in? Or does that depend on what you buy?
Tom
Old Mar 9, 2005 | 11:27 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No... but you will need to get the right speedo gears, for whatever rear gear it has, to go along with it. And hopefully there's a drive gear on the transmission's mainshaft, and even more hopefully, it's the right one to match whatever the rear end gear turns out to be.
okfoz
Convertibles
83
Oct 29, 2018 11:18 PM
Infested
May 22, 2018 11:56 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
GVMV
Aug 16, 2015 08:01 PM
