How to install PST motor mounts??
Old Jul 12, 2001 | 10:15 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
How do I get the motor mount apart so I can replace the rubber section in the middle?? I was expecting the PST motor mounts to come in the metal, but I guess not.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Old Jul 12, 2001 | 10:20 PM
camaroguy99's Avatar
you have to drill out the rivits on each side of the shell, put the new insert in and the zip tie the shell back together. Thats at least the way ES's instuctions tell you how to do it.
Old Jul 13, 2001 | 02:15 AM
age's Avatar
age
Car: 1992 Z28 1LE
or you could always weld the shell back together. that's what was done to my motor mount shell. I figure that with the upgrade from rubber, I'm probably not going to need to replace the mount (at least for a long time). So it got welded, installed, and "forgotten"
Old Jul 13, 2001 | 07:09 AM
ede's Avatar
ede
i followed ES instructions to take them apart but welded mine together in a vise before i put them back in.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
