Pee Pee in the fuel line, what to do??
Old Jul 10, 2001 | 02:48 PM
un4givin89's Avatar
I cauught some punk *** kids going around pissing in peoples cars last night one of them being mine. I haven't started it yet, and I know that could **** it up. Think I should take it to the shop and get them to flush my whole fuel line and tank out for me. Or should I not worry about it?? What to do.
Don't you just love 13 year olds...
Old Jul 10, 2001 | 03:32 PM
LeftTurn1LE's Avatar
Find those little b@st@rds and give them some really long straws.
Old Jul 10, 2001 | 03:35 PM
Stuart Moss's Avatar
Is this one of those things that you'll look back on and laugh?
Anyway, while you're at the auto store getting your locking gas cap, I'd think that using several cans of HEET should be able to "dissolve" (is that the correct word?) the urine into something burnable. Afterall, isn't that what it's supposed to do to condensation?
Depending upon how much urine was "introduced" into your tank, use an appropriate amount of HEET or similar condensation/water remover. I'd imagine you'd have to use quite a bit. Try to start with as full a tank of gasoline as possible to make the resulting "liquid" as weak or diluted as possible.
But don't take this advise as absolute. Just my opinion. Maybe someone will know if draining the gas tank (perhaps by one of the 13-year-old kids?) will be required.
[This message has been edited by Stuart Moss (edited July 10, 2001).]
rezinn's Avatar
Is it actually in the fuel line? I don't think it would hurt anything, but I would make a big deal out of it and make those kids siphon it out and buy you a new tank of gas or something. Tell their parents, "I caught your child urinating in my gas tank" LOL!
Yeah I was thinking about HEET, but I doubt there is much in there. When you said "one of them being mine," you meant your car, not your son.. right? =p
[This message has been edited by rezinn (edited July 10, 2001).]
Old Jul 10, 2001 | 06:52 PM
un4givin89's Avatar
Yeah I ment my car. I am only 19.
Old Jul 10, 2001 | 08:12 PM
irocbsa's Avatar
How much **** can a 13 year old squeeze out???? If he was doing it other gas tanks as well I doubt he would have much of a "present" for each gas tank. I'm a good bit older than those guys and I can't hold enough even after a long night of drowning myself with Coors light. Fill the tank up all the way and run the bitch dry.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jul 10, 2001 | 08:23 PM
Makaveli's Avatar
im 14 :d but i wouldnt **** in a gas tank even if you payed me! well it depends how much.... but anyway... thats just pathetic! LOL the dude i used to work with said that happened to him before, he got the whole thing flushed and it was fine. of course he got like $50 or so from the kid's parents lol
Old Jul 10, 2001 | 08:31 PM
un4givin89's Avatar
This was several kids mind you.
Old Jul 10, 2001 | 08:39 PM
leirch's Avatar
Man, If I found some punk kids running around doing that and I found out that they did that to my car. I swear I would kill them. Maybe not kill them but I would definatly go to jail. You just don't do that and definatly not to my IROC!
Oh man, I'm pissed just knowing that **** happens.
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 SR Cam, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Jul 10, 2001 | 09:21 PM
irocbsa's Avatar
Do you know who they are? Where they live? Man I bet you could get a **** load of money out of their parents. "Uh yeah, the material from your son's bladder caused the fuel injectors to explode ($230 for new Accel 24#-ers) and it ripped holes in the manifold ($400 for an Edelbrock piece). When the manifold blew up it took out my plenum ($100) and my throttle body ($300 for BBK 52mm) which proceded to fly through my hood ($450 for ASCD SS hood) and killed my parakeet. ( this is just for dramatic effect.) The massive vacuum leak caused by all those holes made the motor run so lean that it burnt holes in all the pistons ($500 - your choice of part) which then broke loose and flew through my heads ($1000 for AFR 190s or TFS). Oh yeah, my shifter **** is loose and my seats are stained from when I **** my pants. ($1000 for new 4th gen seats) And one last thing, I'm thirsty and would like a cafe latte, sweet and low, twist of lemon. And a bagel too."
That will teach 'em.
bsa
[This message has been edited by irocbsa (edited July 10, 2001).]
Old Jul 10, 2001 | 09:26 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
lol @bsa-
dude- if ya got an electric pump, pump all the gas out... just disconnect the line at the fuel filter, if it hasnt been run, then its not in the fuel lines yet..
Steve
Old Jul 10, 2001 | 09:36 PM
TRVLIN99's Avatar
At certain times of the year, gasoline right from the pump has more water in it than those little pissers can produce.
Old Jul 11, 2001 | 10:53 AM
Steves ZZ5's Avatar
It's not the water content of urin that I would be worried about, It's the small crystalline structure left over form evaporated urin that would be the bane of the engine. This chemical found in urin is known as "urea"
Just like sugared gasoline, when the urin is passed through the combustion process of the engine, there are certan parts that won't burn. The urin, during the high heat and compression of combustion, will rapidly change from an amorphic state to a state of minute solid structures. These urin "crystals" are what would have an effect on your engine.
Now, depending on whether or not the kids were sufficiently hydrated or not will determine how saturated their urin is with the matrixes to form crystalline.
But, Unlike a pound of sugar in 16 gallons of gasoline, I don't believe that 13-year-old boy urin, even if the child is in a state of dehydration, has enough urea content to cause damage to your cylinder walls. Not only that, but I'm willing to bet that the kids got more **** on the front of their pants than in your tank considering you have an anti-splashback door on the front of the filler neck opening.
To make a longer story longer, I wouldn't worry about the pee too much, but don't tell the kid's parents that. See if you can get some money out of them. Hell, It wouldn't hurt to get your tank drained and flushed anyway...Good preventative maintenance for the years of crud that may have found it's way in there.
86 Trans Am WS6 Black with tinted windows, ZZ4, Mini-ram, true duals, LT4 HotCam, AFR 195 heads.
***Too many other mods to mention***
"In the future, cities will become deserts,
roads will become battlefields, and the hope of mankind
will appear as a stranger"
The Road Warrior
Old Jul 11, 2001 | 11:25 AM
AFRO IROC Z's Avatar
I like irocbsa's idea, then if that doesn't work and the parents blow you off, i would catch the kids and pee pee on them. Or you could take a poo poo on the hood of their parents car and see how they like that, just kidding . hey, could you let us know how you make out, later
Old Jul 11, 2001 | 02:56 PM
Biochem's Avatar
Car: 2002 SOM z28
LOL... To agree somewhat with Steve, depending on just how much Pepsi the kids downed, I doubt there is any sufficient amount of urea in the tank! The percentage of urea in urine is relatively low... then you dilute it a thousand fold with gasoline... You may be looking at 0.000001% give or take.
Besides look at it this way, urea is 1 carbon, 1 oxygen, 2 nitrogens, and 4 hydrogens I believe... I just wouldn't get e-checked soon because your NOx or CO levels may go up a hair.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Jul 11, 2001 | 03:06 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Just cuz they pulled your gas cap off doesn't mean it went into the tank. They would have had to hold that little flapper valve thingie open while they pissed, which means they would have had to **** all over their hand to get it into the tank. I'm willing to bet none made it in.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jul 11, 2001 | 03:20 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
I was thinking the exact same thing Jim. Either that or they stuck their pecker in the filler tube. Thats would be ballsy.
1985 ASCD Ram Air Trans Am
Readers Ride at https://www.thirdgen.org/rides/index...ew&rideid=1067
" I get drunk, I race cars and I fondle women. But... I have weekends off and I am my own boss"
Old Jul 11, 2001 | 03:22 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
yeah but there's thatlittle tab that keeps gas from sloshing back out..
you might have more than just pee-pee in your tank, you might have A pee-pee LOL!
Webmaster: www.IROC-Z.org
Old Jul 11, 2001 | 03:46 PM
One Eyed Jack's Avatar
www.carparts.com
$18 for a locking gas cap
Old Jul 11, 2001 | 04:20 PM
Steves ZZ5's Avatar
BWAAAAHAHAHAHAHHAHHAHHH....we've got too much time on our hands talking about pee and all...
You know what would have been funny? Like mentioned earlier, that little anti-splashback flapper could have trapped a little kid by his weimeriner!!!....That'd be a lesson he'd never forget!!...
Old Jul 11, 2001 | 04:30 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
<font face="Verdana, Arial" size="2">Originally posted by Steves ZZ5:
...Just like sugared gasoline...
...Unlike a pound of sugar in 16 gallons of gasoline...
...Not only that, but I'm willing to bet that the kids got more **** on the front of their pants than in your tank considering you have an anti-splashback door on the front of the filler neck opening.
</font>
Gasoline will not dissolve sugar, it just sits in the tank unless picked up by the pump/siphon.
And probably more so when they got caught.
Personally, I would sit down with the parents and come to terms that would make either the kids themselves pay, or do 'community' service on your property. Be creative. Teach them what it takes to properly maintain a vehicle.
"Question with boldness even the existence of a God; because, if there be one, he must more approve of the homage of reason, than that of blind-folded fear."
-Thomas Jefferson
Old Jul 11, 2001 | 07:51 PM
irocbsa's Avatar
I like that idea.
Y'all do have way too much time on your hands. Talking about the checmical makeup of ****. Sheesh.
bsa
Oh yeah, you need a new gas tank and a fuel pump too. As well as a new rear end since the fuel pump blew up and shot through your axle tubes. ($2000 for a Ford 9", you can give that to me since I'm so damn smart and gave you the idea in the first place. )
bsa
Old Jul 12, 2001 | 02:08 PM
JoeIROC's Avatar
Wouldn't the stuff get filtered by the fuel filter?
86 IROC TPI 305
700-R4 with Trans-go shift kit
K&N Air filters
Dyno-Max cat-back
Summit tranny cooler
CEI throttle enhancer chip
Old Jul 12, 2001 | 03:39 PM
Xenodrgn's Avatar
<font face="Verdana, Arial" size="2">Originally posted by JoeIROC:
Wouldn't the stuff get filtered by the fuel filter?</font>
We're talking microscopic particles here, if anything, urea is thinner than gas. If the fuel filter was that efficient then it would stop the gas from flowing before it stopped the ****.
1985 Camaro SC - 2.8L, auto.
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Jul 13, 2001 | 10:50 AM
Drakar's Avatar
You could always make the kids siphon your tank with a garden hose.
1989 GTA 350 TPI - T-tops, dual cats, 9-Bolt aussie 3.27
1992 RS 305 TBI - T-tops, T-5, 3.08 - Sold
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
