New fly wheel and clutch problem?!?!
Old Jul 11, 2001 | 10:53 PM
JohnnyIroc's Avatar
Car: 85 TA
2 days ago I got my car back from the shop, and I had a new 350 put in with a bunch of new parts including hays flywheel and centerforce dual friction clutch. Well the first time I drove it I said to myself what the hell?!??!! the clutch should catch right off the floor cause its new. But to my surprise the clutch doesnt catch till like 3/5 way up. The mechanic at the shop said it will be fine but I like the clutch to catch lower. The clutch catches well thou so what could the problem be? Any suggestions are wlcome. Thanks
[This message has been edited by JohnnyIroc (edited July 12, 2001).]
Old Jul 13, 2001 | 12:03 AM
JohnnyIroc's Avatar
Car: 85 TA
ttt
88 IROC-Z 350 TPI 5 speed
Performance Resource Chip, Flowmaster American Thunder cat back exhaust, B&M Ripper shifter, MSD coil, TB bypass, TPIS MAT relocation kit , AC Delco 160* t-stat, Richmond 3.73 gears, March Power & Amp pullies, Home made Ram Air, Steve Spohn SFC's, LCA's, and LCA relocation brackets , Panhard bar, TPIS AFPR, Ported plenum by Daniel Burk, Mac Test pipe
Best et: 14.232(all times with 305)
Best mph: 97.76
Best 60': 2.063
http://hometown.aol.com/famioso15/johnnyiroc.html
Old Jul 13, 2001 | 03:27 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
It sounds like the new clutch/flywheel/pressure plate combo has a different total combined thickness (from the crank to the fingers on the pressure plate where the throwout bearing hits). I heard something in a post on the tranny board about a different throw out bearing for use with a centerfoce press. plate...but I digress. You'll most likely get used to it as it operates fine and there's no real adjustment built into the hydraulic setup. I guess you could play with the clutch release fork's pivot bolt, but that means the tranny has to come out to it's probably not worth it.
hth
Clem
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
Omega
Oct 1, 2015 02:20 PM
milk
Aug 10, 2015 06:26 PM
Fronzizzle
Aug 9, 2015 01:15 PM
rsrmoore
Aug 7, 2015 08:44 PM
