faster engine warmup...
Old Jul 13, 2001 | 09:18 AM
carter89RS's Avatar
i have a stock L03, and when i start it up it idles around 1500 for about 4/5min before dropping down to around 800.
what can i do to have it warmup faster?
Old Jul 13, 2001 | 11:48 AM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
rev it up to 8000rpm, just kidding..
does your car still h ave the heat stove that comes from the exhaust manifold to the aircleaner? you might want to check and make sure that you have an airtight seal there so that all of the heat is going into your carb..
other than that, not really.. changing your thermostat won't help because temperatures will be too low..
you might be able to adjust your cold idle screw to idle the car at a lower rpm, like 1100-1200
Webmaster: www.IROC-Z.org
[This message has been edited by ColinOpseth (edited July 13, 2001).]
Old Jul 13, 2001 | 01:11 PM
carter89RS's Avatar
i would assume it still has the heat stove, i just got my hands on it and i dont think any mods have been done yet
how would i check to make sure it is on tight/sealed?
Old Jul 13, 2001 | 09:09 PM
NHcamaro's Avatar
I have a 88 SC does the same thing
1988 Sport Coupe 305 TBI
K&N
Flowmaster exhaust
Daily driver:
1988 K1500 5.7 4x4 shortbed flowmaster cat-back gutted cat.
Old Jul 13, 2001 | 09:13 PM
Engine: 305TPI
<font face="Verdana, Arial" size="2">Originally posted by carter89RS:
</font>
just make sure that the aluminum heater tubing going from the stove to the aircleaner is in good shape, it may not be aluminum but that black fabric stuff with the coil embedded in it..
Old Jul 13, 2001 | 10:29 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Its all part of the eprom. You can adjust the Idle Speed Vs Coolant Temp inside the eprom.
Grant2k
Jul 10, 2018 04:01 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 19, 2015 10:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
