Good "cam" Grief...
Old Mar 12, 2005 | 06:04 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
Good "cam" Grief...
Old Mar 12, 2005 | 06:35 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Did you use a piston stop to find true TDC?
Old Mar 12, 2005 | 06:57 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Yes I did,....
Old Mar 12, 2005 | 07:04 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Re: Good "cam" Grief...
Originally posted by GTA
I cannot get any of the cam card #'s and the cam has barely any lobe lift at all??? I Must be doing something wrong , does any one have any ideas?? thank you ...GTA
Elaborate on not being able to get any of the cam card #'s.
How are you measuring lobe lift?
What kind of cam..hydraulic, roller, etc?
Old Mar 12, 2005 | 07:12 PM
F-BIRD'88's Avatar
Yes I did,....
If you accuratly determined True TDC and the balancer pointer show something else, then the balancer and or pointer is out of spec. The outer ring on stock balancers can move. If thats the case you should replace the balancer cause it will soon fail.
If you try to measure cam lifter lift using a hydraulic lifter you'll get inaccurate readings. ( cause the internal plunger compresses) Either us a solid lifter while degreeing or set the dial indicator up to read off the edge of the lifter body.
Old Mar 13, 2005 | 12:35 AM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Time for a new balancer. Go by the dial indicator, and forget about the balancer for now. At least for degreeing in the cam. If your balancer comes apart going down the road it WILL do some damage. Also if you're using an 8" degree wheel , it may not degree at the specs. Comp Cam figures is for a 12" degree wheel.
Old Mar 15, 2005 | 05:37 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Oh, I just would like someone's opinion on this....."we" used a flat tappet to check for lift....I know now that I should have put one of the stock Rollor tapets back inthere for the measurment....Would this cause the false readings?? thanks GTA...
Old Mar 15, 2005 | 06:08 PM
F-BIRD'88's Avatar
Why would you use a flat tappet to check a roller cam?
Old Mar 15, 2005 | 06:36 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
Aug 19, 2015 10:29 PM
