91Z running rough after I made her pretty
Old Mar 13, 2005 | 03:35 AM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
Last year before Super Chevy @ Indy, I was cleaning up my car and decided to "wash" under the hood. It is clean, but was dusty from driving. I went to the local car was and used the baton to clean under the hood.....lowest setting with no pressure. It ran fine for the next 2 hours, but for some reason started acting up later in the night. The engine revs really high (1200-1400 rpm) at idle and really falls on it's face on the top end. This car really hauled bauls b4 I did this.
I heard that there are several things that are very suceptable to water under the hood. I heard that the throttle position sensor is one thing that should never get wet. I am sure it did that day. It is getting warm and I want to get her out, but not running like this. Any ideas will help......
By the way, it's a 1991 Z28 5.7L TPI. It is showing the service engine light right now, and I hope to get it in to Chevy to see what code it's throwing, but does anyone know what this may be?????
Thanks,
Dylan - 911rsq
Old Mar 13, 2005 | 04:28 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Cold water can fracture the spark plugs on a hot engine.
Old Mar 13, 2005 | 06:15 PM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
you can check the codes with a paperclip from under the dash. maby someone can elaborate more.
Old Mar 13, 2005 | 09:11 PM
Stevo's Avatar
Car: Pair of 92 Z28s
water in the distributor?
i dont think that would put the SES light on..but who knows
just an idea
Old Mar 14, 2005 | 02:54 AM
911rsq's Avatar
Transmission: yes
I will check the plugs tomorrow, but it sounds and feels like it is hitting on all 8 cylinders. Moisture might have gotten under the distributor, but this was last fall and it still runs rough.... . I am in the process of trying to sell the car and I want everything to be perfect....
Old Mar 14, 2005 | 01:45 PM
Mo's Avatar
Mo
I killed my IAC by getting it wet, idle went up, wouldn't start very well, no code though...
Old Mar 14, 2005 | 02:38 PM
sellmanb's Avatar
Car: '86 Berlinetta
KISS.
Did you knock any vacuum lines loose, and then they fell off two hours later? Might want to check that.
If that shows up good, then you can test your IAC.
It sounds like a vacuum leak to me, but I'm no expert... just gotta find out where it might be coming from.
Old Mar 15, 2005 | 11:26 PM
911rsq's Avatar
Transmission: yes
Cool, I will do that in the moring....vacuum and IAC...got it!!
Old Apr 7, 2005 | 12:15 AM
911rsq's Avatar
Transmission: yes
Alrighty....checked it all out. Distributor is dry. Had a friend of mine hook it up to his scan tool at his garage and the TPS voltage is low. Will have a new one here by tomorrow and hopefully problem solved. Thanks all......
Old Apr 7, 2005 | 12:30 PM
HawaiianRS's Avatar
Car: 1989 RS
Engine: 5.0
Why not just try adjusting the TPS?
Old Apr 7, 2005 | 01:53 PM
sellmanb's Avatar
Car: '86 Berlinetta
and cleaning it
Old Apr 7, 2005 | 01:56 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
exactly - what he said... probably just loose. you'll need a volt meter to reset it, but you can tell if it's loose obviously just by checking it.
Old Apr 7, 2005 | 05:56 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Yeah it's NEVER smart to clean an engine like that.. for a few reasons.
1. It was hot. Hot block + Cold water = Cracked block. Seen it happen.
2. Should have covered up sensitive stuff, i.e. TPS.
3. Should have used simple green, rags, and a spray bottle of water, not a hose.
Old Apr 10, 2005 | 10:22 PM
911rsq's Avatar
Transmission: yes
I agree that it is a bad way to clean under the hood, but I was doing a last minute trans rebuild and ran out of time and didnt get to really detail it out..... Just hosing off the loose stuff to go to the show. I am def going to try to adjust it first, but from the readings we got on the computer, it's prolly shot...
I am going to check it out either way. I have the new one here just in case..
customblackbird
Aug 15, 2021 10:16 PM
Bradsaundry
Aug 12, 2015 12:34 AM
apie2546
Aug 10, 2015 05:43 PM
Sherpajames
Aug 7, 2015 06:56 PM
