Found my a/c problem...whats the way to repair it? (vader?)
Old Jul 15, 2001 | 09:58 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
ok...went and bought some r134a refrigerant and the hose to try and charge it again..the a/c compressor turned on and the clutch moves.... 2 secs later i heard why i havent been able to hold refrigerant in the system.. on the high side the valve stem over there is leaking.. i pulled it out and the o ring and everything was still in tact... ideas? Its definentely that high side valve stem...if i put my finger over the opening, the hissing sound goes away... can i simply just buy a valve stem? if so..is it a GM part?
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
#3 Forever
Old Jul 15, 2001 | 11:02 PM
btt
1989 Firebird
Coming for my v6:
#3 Forever
Old Jul 15, 2001 | 11:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's a more or less regular Schraeder valve core. I wouldn't go back to GM for it. If you have a Blackstone in your area, that would be a place to start. Otherwise, NAPA or some other real parts store would have them; or any place that sells appliance/refrigeration parts.
ICON Motorsports
Old Jul 15, 2001 | 11:25 PM
Guest
Guest
Posts: n/a
Dime a dozen part from any decent parts store... meaning not autozoo, etc.
Most will try to stick ya with the carded stuff that comes 2 or 4 to a pack, but other places will have them in a box and will sell them one at a time.
Old Jul 15, 2001 | 11:29 PM
I compared it to my shraedar(sp) valve core and they didnt look at all the same?? I have a Fuel pressure gauge so im not using the old valve core.. can i swap them?
1989 Firebird
Coming for my v6:
#3 Forever
Old Jul 15, 2001 | 11:32 PM
btw..what would the "technical name" on that part be?
1989 Firebird
Coming for my v6:
#3 Forever
Old Jul 15, 2001 | 11:53 PM
Guest
Guest
Posts: n/a
AC valve core?
The one from the fuel gauge should work provided the o-ring is ok and the same size as the one on your ac... and it probably is.
neilb
Oct 4, 2018 12:36 AM
BHR
Sep 3, 2015 07:51 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
