Before I order... is this the cam I definately want??
Subscribe
Mar 17, 2005 | 09:51 AM
Ok, I'm about to buy the last part for my motor. I now have everything, and all I need is a cam!
I know I've posted many things about this setup, but I want to make this work the first time and as good as it can be!
So, here's the setup:
1969 350, stock bore 2bolt main
Trick Flow Twisted Wedge G2 heads
Holley Stealth Ram
52mm throttle body
Summit 1.5 roller rockers
Hooker headers with 3" y-pipe and the 3" all the way back
This is the cam that was suggested: Comp cam with lifters CCA-CL12-268-4
Now, is that the best for my setup? What pushrods should I get? Thanks again!!
Reply 0
Mar 17, 2005 | 09:53 AM
Hey, 1700 posts!
http://store.summitracing.com/defaul...h.asp&x=37&y=6
CCA-CL12-268-4 $189.95
Estimated Ship Date: Today
OverviewBrand: Competition Cams
Product Line: Competition Cams Xtreme Energy Cam and Lifter Kits
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,800-5,800 RPM
Intake Duration 050 inch Lift: 224
Exhaust Duration 050 inch Lift: 230
Duration at 050 inch Lift: 224 int./230 exh.
Advertised Intake Duration: 268
Advertised Exhaust Duration: 280
Advertised Duration: 268 int./280 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.479
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.480
Valve Lift with Factory Rocker Arm Ratio: 0.479 int./0.480 exh. lift
Lobe Separation (degrees): 114
Intake Valve Lash (in): 0.000
Exhaust Valve Lash (in): 0.000
Grind Number: CS XE268H-14
Computer Controlled: No
Lifters Included: Yes
Lifter Style: Hydraulic flat tappet
Valve Springs Included: No
Retainers Included: No
Locks Included: No
Valve Stem Seals Included: No
Timing Chain and Gears Included: No
Assembly Lubricant Included: Yes
Pushrods Included: No
Rocker Arms Included: No
Gaskets Included: No
Quantity: Sold as a kit.
Get Xtreme performance from Comp Cams.
Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 268/280, Lift .479/.480, Chevy, Small Block, Kit
Comp Cams Xtreme Energy cam and lifter kits are built to take advantage of the latest cam technology, to provide maximum performance. Whether your use is off-roading, towing, or street performance, there is an Xtreme Energy cam and lifter kit available for you. By using an aggressive lobe profile, these cam kits provide better throttle response and more top-end horsepower than equivalent kits from other manufacturers, while delivering increased engine vacuum.
Reply 0
Mar 17, 2005 | 10:18 AM
I think it should work fine.
You won't know what push rods you need until you can mock up the whole valve train on there. Given that those heads are notorious for requiring unusual push rods, the thing to do would be to order an adjustable push rod when you order the cam; install it; measure for the correct rocker geometry (see Comp's web site for instructions); and then order push rods based on your measurement.
Reply 0
Mar 17, 2005 | 10:37 AM
Ahh ok, sounds like a plan. I think I'll let the engine shop do the ordering then!
The lifters that come in that cam kit will work fine with my block, correct? I'm not sure how all the sold/hydraulic things work.
Reply 0
Mar 17, 2005 | 10:46 AM
Yes. You just use regular flat-tappet lifters, and a regular pre-"factory roller" timing set such as a 3100, and leave the retainer plate out.
Reply 0
Mar 17, 2005 | 12:38 PM
There shouldn't be a retainer plate on a '69 350.
Reply 0
Mar 17, 2005 | 12:46 PM
I hope not, because I don't know what that is
Reply 0
Mar 17, 2005 | 01:07 PM
Well OK, so don't use one
Reply 0
Mar 23, 2005 | 05:26 PM
Well, the heads came with Trick Flow pushrods, marked 7.900 .080
I don't know what that means, but I shouldn't reuse them anyway, right?
Reply 0
Subscribe
