I need some quick help!!!!
Old Mar 17, 2005 | 09:55 AM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
Here is my story, i hope you guys can help me. Kinda long, but please bare with me.
Brand new 355 installed in my bird. Everything is peachy except for cylinder number 2. When running i noticed that cylinder was not getting hot. I changed the plug, still not better. unplugged the injector for the cylinder and ran the motor with a brand new plug in it, took the plug out and it was covered with gas, even with the injector unplugged.
That led me to believe that the injector was just dumping fuel on that cylinder(that all ohmed out at 13.5). I bought a brand new gm injector to try to fix it, same problem.
I swtiched the #2 and #4 inejector wires on the harness to make sure it was not in the wiring for the injectors. Still same problem.
I am getting great spark there, well the spark looks the same as it does on the other cylinders.
I did a compression test on all cylinders, 180 across the board.
any idea what could be causing this problem?
Old Mar 17, 2005 | 09:57 AM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
are you sure its fuel and not oil on the plug?
Old Mar 17, 2005 | 09:58 AM
Car: 1989 Iroc-Z
Engine: 350ci SBC
also try running the valves on number 2 again...could have one hangin open...most likely not since you did the comp test and it came back ok.....how does the motor run?
Old Mar 17, 2005 | 10:15 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Check the plug wire (probably arcing to ground somewhere); look in the dist cap.
Sounds to me like a no-spark situation and of course the plug is drenched with fuel because it just passes through the cyl and wets the plug int he process.
Old Mar 17, 2005 | 10:19 AM
Car: 1989 Iroc-Z
Engine: 350ci SBC
how is the plug getting fuel soaked if the injector is brand new and unpluged???
Old Mar 17, 2005 | 10:21 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The usual way.... by air/fuel mixture getting sucked in from other cyls when that valve opens.
Don't try to outsmart yourself. Try the simple stuff first. Don't "think" too much, just inspect the car, and find the problem. It'll be running right a whole lot sooner that way.
Old Mar 17, 2005 | 02:37 PM
9D1BURD's Avatar
Car: 1997 Z28
Yeah it is def gas on the plug.
I did not see any arcing with the hood open in the dark. I put a new plug in there, when i pulled the plug to see the spark, it had great spark.
What do i need to look for on the dist cap, it is new also. I will also check the valve lash again.
It runs pretty darn good on 7 cylinders, although i am not driving it that way.
I believe there is something going on in the cylinder spark wise, the primary will get warm, but never hot.
Old Mar 17, 2005 | 02:42 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
ohm out the wire on that cylinder and see if its bad......replace the cap and rotor again they are cheap......swap the wire with a known good one, turn the lights off in the garage and look closely at the wire and see if its arching. if all else fails swap dizzys.
Old Mar 17, 2005 | 02:52 PM
9D1BURD's Avatar
Car: 1997 Z28
I have swapped the wires, i will replace the cap and rotor tonight.
Old Mar 17, 2005 | 07:20 PM
sellmanb's Avatar
Car: '86 Berlinetta
sounds like that one terminal in the dizzy cap is corroded out... try just cleaning it off with a screwdriver or something before you go and spend money on a new one... just going around replacing parts until you find the right one isn't exactly productive. lol.
Old Mar 17, 2005 | 07:32 PM
9D1BURD's Avatar
Car: 1997 Z28
I will try that tonight.
I have a theory that maybe my exhuast vavle is hanging open not allowing proper combustion.
keep the ideas coming, thanks
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
