What should the fuel pressure be?
Old Mar 18, 2005 | 06:30 AM
Notplayn's Avatar
Car: Depends on the day!
Engine: the kind that runs on money
Transmission: One that holds up, I hope
With a gauge hooked up to the fuel rail, what should the fuel pressure be just turning the key on??
Old Mar 18, 2005 | 11:53 AM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
You'll need to mention what sort of engine you're running. Also is it the stock fuel pump, etc.
carbs should have a pressure of 6-7psi, injectors need much more. But mine has a mechanical pump, and that means that until the engine is cracking, you get nothing.
Si.
ps. Also would have thought a search would yield the answer.......
Old Mar 18, 2005 | 12:55 PM
Notplayn's Avatar
89 gta 350 tpi stock fuel pump.
Old Mar 18, 2005 | 01:31 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
I think its like 43 or around there.
Old Mar 18, 2005 | 01:33 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
With the car at Idle, it should be at 36/38 PSI. This is for a stock TPI car.
Old Mar 18, 2005 | 01:58 PM
Notplayn's Avatar
the pressure with the key on, not running. My car will not start and I am going through the paces. 35/36 is where it is at, again not running, only with key on.
Old Mar 18, 2005 | 04:17 PM
DJP87Z28's Avatar
So you do have correct fuel pressure.
Old Mar 18, 2005 | 06:54 PM
Notplayn's Avatar
I guess so, so let me ask, will old gas keep a vehicle from cranking? I mean it is not even trying to run.
Old Mar 18, 2005 | 07:01 PM
DJP87Z28's Avatar
Not really. You have other problems if its not even trying to run.
You did not describe whatr is happing.
Old Mar 18, 2005 | 07:21 PM
Notplayn's Avatar
I just got the engine together. Vehicle turns over fine, checked spark, good. Pulled number one plug, wet with gas. Question.. on an 89 gta tpi engine 350, is it possible to mix up the injector connectors. I am running out of things to try. thanks for any help
Old Mar 19, 2005 | 09:55 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
No, all the injectors on one side have a common 10 amp fuse, and each side is switched to ground by the ECM.
Old Mar 19, 2005 | 09:59 AM
rsn932's Avatar
if you have air, fuel, and spark it could be a timing issue. the distributor could be 180* out?
Old Mar 19, 2005 | 10:11 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Get the timming light out! but check to see if you have a timming control link that has to be disconnected first. That should tell you if your in the ball park with the dist. install. You'll need some one to cranck it for ya unless, you have real long arms!
Old Mar 20, 2005 | 12:14 AM
Notplayn's Avatar
disconnect the est wire, connect the timing light to #1 and go from there right?
Old Mar 20, 2005 | 01:19 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Yes, 6° BTC. Don't forget to connect the Set Timing Connector back up.
Old Mar 21, 2005 | 02:30 PM
Notplayn's Avatar
dist was 180 out. It will start up and run, cuts off when put into gear. working on that now.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
