Flexplate Removal
Old Mar 19, 2005 | 05:07 PM
sellmanb's Avatar
Car: '86 Berlinetta
Flexplate Removal
I didnt seem to have a problem removing the flexplate from my 1pc RMS 305 block. But I just got a motor out of a 75 El Camino, and it has a 2pc RMS 168T Flexplate. So I went to the parts store, and got a 2pc RMS 153T Flexplate.
Got all the bolts out of the flexplate, but there's something holding the flexplate in still by the middle. How do I remove this?
Here's a visual:
Old Mar 19, 2005 | 05:08 PM
sellmanb's Avatar
Car: '86 Berlinetta
another view
Old Mar 19, 2005 | 05:23 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Just a bit tight due to a corrosion around the crank/flywheel. Spray the area with penetrating oil and tap it a few times with a rubber mallot.
Old Mar 20, 2005 | 08:57 PM
sellmanb's Avatar
Car: '86 Berlinetta
you were right... I just didnt have enough patience with it
Here's a pic of the new flexplate on (with same old starter... still gotta change that out lol)
Is there a certain torque pattern and ft/lbs I need to torque them to? My manual doesnt say, or I cant find it lol.
Old Mar 20, 2005 | 09:22 PM
Engine: SBC, LS-x
Tq them down in stages in a star like pattern like you would with a rim ect. I don't remember what the final tq. values should be but I'll crack open a book and grab the #'s if nobody has answered by then.
Old Mar 20, 2005 | 09:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Happened to have my helm manual in my lap while browsing this thread...
Figured you may need a few other torque specs, so here are a few...
assuming it's the same for all SBCs (safe guess.), here it is for an LG4 in '82.
Attached Thumbnails Flexplate Removal-c-documents-settings-jay
Old Mar 20, 2005 | 09:40 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
60-65 ft lbs on flywheel bolts
torque in cross pattern (like a u would a rim)
Old Mar 20, 2005 | 10:00 PM
Vader's Avatar
Just get a starter with a really big pinion gear. That way, it will crank faster, too.
Looks like the project is coming along.
Hopefully, both sets of holes are drilled/tapped for the starter.
Old Mar 20, 2005 | 10:56 PM
sellmanb's Avatar
Car: '86 Berlinetta
Thanks for all the info. I ended up tightening them down in a star shape, and tightening them down w/ my breaker bar until I couldnt torque 'em anymore comftorably (by hand, and I'm weak lol). I'll back them off and torque 'em down to 60ish.
Thanks for the kind words Vader I am hoping that it's tapped for both types of starters as well... I'm REAAALLLY hoping it is... dont wanna have to have machine work done to it, hoping to drop n go lol
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
Stangski09
Nov 14, 2015 01:27 PM
Stroopwafel
Sep 11, 2015 06:38 AM
roysatikas
Sep 7, 2015 08:08 PM
