pushrod length
Old Mar 20, 2005 | 11:32 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Axle/Gears: 3.23 for now
pushrod length
Not be to be a pain but just trying to expand my knowledge. What is the importance of having the correct push rod length? I mean what are the signs / results of a pushrod thats too short?...too long? Is there a mathematical formula for this or is the only way to find out is by using a measuring tool? Im just curious as Ive gone to a new cam and wanted to know if I needed new pushrods. New cam is 08-305-8 and was using stock length pushrods before. Thanks for any info.
Kris
Old Mar 21, 2005 | 05:08 AM
ede's Avatar
ede
broken parts are good indicator of incorrect length reason you'd want correct lenght is to maintain propper valre train geometry.
Old Mar 21, 2005 | 07:17 PM
Mr_Happy's Avatar
Use a rocker arm geometry checker Manley 42137 to check the push rod length.... About $15
Old Mar 22, 2005 | 03:37 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
you can get pushrods .100 longer so it extends it almost like getting 1.7 ratio rockers from a 1.5 i believe. maybe wrong tho
Old Mar 22, 2005 | 11:48 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
In fact, it's nothing like getting 1.7 ratio rockers from a 1.5.
Using the correct length pushrod will give you the correct valve lift. Using the wrong length will give you reduced valve lift, at best, and broken parts at worst.
wigmobile
Feb 26, 2025 02:56 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
mfp189
Sep 27, 2015 09:25 AM
Scorched1984
Sep 15, 2015 03:42 PM
