Anyone know how to make a belt stay on?
Old Jul 21, 2001 | 12:13 AM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I have a belt problem. These things keep coming off. I have a Moroso deep groove racing pulley and everything. I have lined it up with string and everything. All of my brackets are tight. I have used all brands of belts. It is a V-belt setup. Any suggestion?
Old Jul 21, 2001 | 12:27 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Do you have an oil leak? I have an 88 dodge that leaks from the main seal onto the alternator belt which makes the belt expand over time and slip. Just a thought
Old Jul 21, 2001 | 12:42 AM
91z4me's Avatar
Super glue. LOL just kidding I don't know my but from a hole in the ground. Just trying to make someone laugh.
91 z-28 305 700R4
3.73 gears out back
T-Tops and Black all over.
Old Jul 21, 2001 | 01:27 AM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
Thats really weird, all that I could think of is maybe one of the pulleys got kicked down and is at a shi**y angle now. That could cause the belt to slip off after a while. Check the pulleys with a level and make sure that they are riding right. I've never heard of belts just falling off... I suppose if that doesn't solve it you could hire a midget to hold the belt in place while your driving down the road, but if he slips thats gonna stink like a b*tch.
Mike
1989 RS.. 355, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job, 3 inch cat-back exhaust, 3 core radiator, 3.73 gearing with POSI.
Old Jul 21, 2001 | 09:01 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Every time I have seen belts come off it was because of a misalignment of one of the pulleys or worn or wobbly pulleys, find a good FLAT metal straight edge and check the pulleys that way for alignment, a string is not as good.
92 Camaro RS 5.0 5-Speed (Quasar Blue)
T-Tops
14" Open Air Cleaner
3.08 Posi-trac
Edelbrock TBI Intake
Crane cam
Ported & polished stock heads 3 angle valve job
HyperTech Chip
SLP Headers (Ceramic Coated)
UltraFlo cat-back exhaust
74 Dodge Dart Sport 360 (11.2 1/4 mile)
2000 Dodge 1500 Ram Sport
Old Jul 21, 2001 | 10:40 AM
82z's Avatar
82z
Make sure your pulleys are completely aligned all the way around, not just at the top. Maybe one of your accessories is angled out at the bottom.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Jul 21, 2001 | 11:52 AM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Thanks guys I'll check with a straight edge.
1992 Trans Am
May 10, 2023 07:19 PM
xxx3man`
Sep 23, 2015 10:37 PM
perZ
Aug 21, 2015 05:51 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
