89 IROC Won't start
Old Jul 20, 2001 | 01:48 PM
N_IROC's Avatar
89 IROC Won't start
New battery and distributor last fall.
The car sat over winter and spring.
Car cranks and has corrrect fuel pressure at the rails.
When ignition key is released to return to the "Run" position the car fires once. No spark while cranking.
thanks
[This message has been edited by N_IROC (edited July 20, 2001).]
Old Jul 20, 2001 | 02:08 PM
Like a ROC 89's Avatar
Check VATS!!!!!!!! See the tech article on this site: https://www.thirdgen.org/newdesign/tech/vats.shtml
Old Jul 22, 2001 | 01:20 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Don't think it's VAT's, if it were, car wouldn't crank.
Got gas? Got good gas? My my estimation the stuff in the tank is 8-9 months old?
Have someone tuen it over, and pull the number 1 plug wire, make sure you're getting good spark.
[This message has been edited by 8Mike9 (edited July 21, 2001).]
Old Jul 22, 2001 | 11:06 AM
N_IROC's Avatar
Like I said. It has NO spark while cranking. It has correct fuel pressure at the rails and the injectors are clicking. As soon as I release the key fron "crank" to "run" it then fires once on one cylinder.
Thanks for the replies, I haven't had a chance to check the VATS recommendation yet.
Old Jul 22, 2001 | 11:56 AM
N_IROC's Avatar
The VATS wires on my car are a pair of white wires in an orange sheath. They connect to a white and purple/yellow stripe wire. The ohm is consistant with the key in all positions, off, run, and start. It must be in the distributor. I'll try swapping that this week.
Derick15
Sep 17, 2016 05:28 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
mustangman65_79
Aug 11, 2015 03:17 PM
