can i install a cam with engine in car
Old Apr 2, 2005 | 07:27 PM
  #51
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Originally posted by Abubaca
I know this isn't important to everyone, but if you have the time. CLEAN EVERYTHING! ...and paint too. It made a world of difference!
Here's at the end of the teardown day!
You know Ab? I've seen that image waaaaaay to many times.
Shiney....
Old Apr 2, 2005 | 07:59 PM
  #52
88tatpi's Avatar
Car: Z28HO/TA/Alfa Romeo
Engine: 305-350-502
Transmission: 700R4-5speed
cam swap in car????
Wow. Almost anything is possible but may I ask why?
I cannot imagine swapping cams "in car" unless there's a major urgency. Like at the track in between races or qualifying or test days.
In a use street motor/daly driver situation swapping a cam on a used motor where the valve seals and lifters have a certain set is rather a risky venture (Unless of course you are performing major conversions of heads, lifters, springs, etc.).
If I were doing such extensive mods I would want to pull the motor and go over many other details and take my time.
Good luck and take care!
Old Apr 2, 2005 | 08:33 PM
  #53
Why not? Its the same amount of work, really less actually. Though it does take more time to do it in the car because you have to work around the engine bay. And tightening headers may be more difficult.
Old Apr 2, 2005 | 09:56 PM
  #54
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
why would i have to retighten my headers for im not taking off the heads. im doin it in the car as i have my spare engine on my stand and i dont want to take it off. also if i do it in the car its gonna make me finish the job in a given amt of time of about 2days unlike if i do it on the stand i might leave it there for a month or 2. im only doing a cam lifter pushrod swap. if iwere to do the springs i would have to take off the heads as my tool requires me to do so.
Old Apr 2, 2005 | 11:17 PM
  #55
In my last post I was talking about a head/cam/intake swap which would require removing manifiolds/headers.
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
drathaar907
Aug 6, 2015 04:20 PM
