Temp Guage not working, where is the sensor?
Old Jul 21, 2001 | 09:20 AM
Ant87IROC's Avatar
Car: 87 IROC Z28
Transmission: TH700R4
My temp gauge stoppped working after i installed my crane 2032 cam. I thought the sensor was in front of the manifold but turns out that doesn't control the guage and my chilton is showing it somewhere on the block by the motor mount. Im lost, cant find it... can someone please help?? Thanks! Need my temp gauge!!
Old Jul 21, 2001 | 11:40 AM
ede's Avatar
ede
should be in the left head between and above 1 & 3 plugs.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jul 21, 2001 | 03:11 PM
Ant87IROC's Avatar
Car: 87 IROC Z28
Im guessing you mean drivers side head? Since the number 1 plug is on the drivers side.... which would be on the right if you face the motor... ?? Just making sure, I didn't see any sensor there, but I will double check
Ant
87 IROC 305 TPI
Old Jul 21, 2001 | 04:57 PM
Enkil's Avatar
Actually, it's right around the 6th and 8th plugs, passenger side head. Easiest to get to from the bottom of the car, but expect some coolant to drain out.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jul 22, 2001 | 01:16 AM
Omar's Avatar
Actually, ede is correct. It's on the drivers side head, between the #1 and #3 plugs. You can see it from the top.
The switch on the passenger side head by #6 and #8 is for the fan.
When referring to sides, left is the driver side, and right is the girlfriend side.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Jul 22, 2001 | 01:47 AM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
ede and omar are correct
Old Jul 22, 2001 | 07:42 AM
GTA88's Avatar
While we're on this topic.... does the temp sensor between the 1 and 3 plugs control the warning light as well as the guage ? My ex-mech ripped the wire off that goes to it when he changed my plugs. Would having this sensor disconnected affect driveability ? I would guess not, since the ecm would read the cts in front of the head , for temp readings, right ?
88 GTA Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Old Jul 22, 2001 | 03:33 PM
JPrevost's Avatar
Car: 91 Red Sled
Guage temp sender is on the drivers head. Look imbetween the headers. The sensor on the passengers side is for the fan if you have TBI. Not sure if you have TPI because I know there are 2 fans and they are controlled by the ecm. The ecm reads off the cts which is on the front of the intake manifold.
, Jon (350 TBI!)
91 Red My website
Old Jul 22, 2001 | 05:35 PM
Enkil's Avatar
Okay, I'm a bit confused...
What's the sensor in the passenger side head, what's the sensor on the intake manifold, and what's the sensor on the driver's side head?
89 iroc-z 305 tbi
Old Jul 22, 2001 | 07:29 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
<font face="Verdana, Arial" size="2">Originally posted by Enkil:
</font>
Pass. side head between #6 and #8: Electric fan
Intake manifold: ECM
Drivers side head between #1 and #3: Temp gauge
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Ghettobird52
Jul 5, 2024 11:18 PM
9192camaro
16
Feb 3, 2019 12:21 AM
TheExaminer
Aug 26, 2015 04:59 PM
squiggy2
Aug 9, 2015 09:30 PM
