Manifold leak - can this cause idle problems?
Old Jul 23, 2001 | 06:38 PM
sdevine's Avatar
Gradually getting worse, my car was having trouble holding its idle above 500rpm after a warm startup (only for a few accelerations each time and then everything would be fine).
Now, I can hear a manifold leak at the engine and the RPMs drop real quick when i push the clutch in. Sometimes it just stalls out, other times it bare idles at around 500. My Tac normally reads 750ish when its warmed up.
Can these 2 problems be related? I remember the last time I had an idle problem, a vaccuum tube had been chewed through. I know this is exhaust gas, but could it be "too easy" for the engine to get the exhaust out and have the idle drop real quick because it doesnt have to do any work forcing the air out? The idle drops so fast, its hard for me to shift in time before the engine is spinning slower than the clutch.
Btw, there are no codes in the computer.
86 2.8 V6
Old Jul 23, 2001 | 07:25 PM
ede's Avatar
ede
yeah fix the intake leak and then come back and post if the problem is still there.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jul 23, 2001 | 07:47 PM
sdevine's Avatar
Sorry, im not sure if i made myself clear. Its leaking at the exhaust manifold.
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
perZ
Aug 21, 2015 05:51 PM
wayshegoes
Aug 17, 2015 12:00 PM
