Do I need short or tall valve covers?
I am going to buy some aftermarket valve covers, and they come in two sizes. Tall and short, should I go with the tall to be safe or will the short be okay?
Founder of the Greater Cincinnati F-Body Association
1988 Yellow Trans Am GTA
Click here for photos
I'm pretty sure that the OE valve covers are of the "short" variety. The long ones are usually just for looks, but sometimes needed for real big rocker arms, which I'm sure you don't have.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, LPE High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
L98 TPI 350 (5.7L)
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
<font face="Verdana, Arial" size="2">Originally posted by Dan87IROC-Z:
</font>
</font>
George P. Lara
1984 Z28
2001 SS #0391
SCCA, SCFB, SC3GFB
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
wil this be for your new motor Brian?
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
I would add that you might have some issues with using the tall VCs and alternator clearance. I had a driverside mount alternator with a serpentene belt and the alternator hot terminal would touch on the vc. The chevy valve covers like these will fit but not much else http://cgi.ebay.com/ebaymotors/aw-cg...item=593347750
2QUIK4U
Sep 1, 2015 09:50 PM
NBrehm
Aug 25, 2015 11:49 PM
