Temp Guage Sensor Question
I think my ex-mechanic screwed up the wiring to my temp sensor in the drivers side between #1 and #3 plugs when he was changing the plugs. There is a wire coming up there with a rectangular connector on it. The wire is just hanging there saying 'connect me to something'. But the temp sensor just has a stub of a bare wire poking out of it. Looks like whatever used to be the connector on the sensor has been knocked off. If I get a new sensor will it have a rectangular terminal for this rectangualr connector on the end of this hanging wire ? Any way I can reconnect the wire to the sensor without buying a new sensor ? btw, I know the mech should pay for it, but that's a whole nuther story....
Thankx
88 GTA 5.7 TPI Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder
than normal.
Thankx
than normal. The connector on the sensor is a round tab. The slot in the rectangle part slides over it until it clicks.
You can also get the kind that is a standard flat type connector but that will not work with the rectangle connector you have.
Thanks. You don't mean round like a small ball, do you ? I assume you mean round on the end, but flat, like the end of a popsicle stick, right ?
than normal.
than normal. Ah. Well, that's what it looks like now, a small nail head, I think. But it also has a very thin wire about 1/4 inch long coming right out of the center of the nailhead, I think. Geez, maybbe I can just hook up the rectangular connector to the nail head. Wow, never saw anything like that before. Thanks for the help.
I'll try reconnecting it tonight.
than normal.
I'll try reconnecting it tonight. ------------------
than normal. Thread
ambainb
Apr 25, 2016 09:21 PM
