cuts out when giving gas
Old Mar 29, 2005 | 02:34 AM
tyisfly0o0's Avatar
Car: 1988 camaro iroc-z
Engine: L98 5.7 tpi
Transmission: 700 r4
when starting the car sometimes it will idle right but it will eventully wanna die but i can barely touch the gas and it will idle back up if i push the gas further down it will die as if it was choking.. when in drive it just cuts out like its running out of gas..its throwing a code 44 " lean 02 sensor" and suggestions??
Old Mar 29, 2005 | 06:24 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Lean
Fuel delivery
Change the fuel filter. Check fuel pressure UNDER LOAD; should be around 38 psi no-load (idling), 43 psi full load at 3000 RPM or so.
If the filter doesn't fix it, prepare yourself mentally for replacing the fuel pump.
customblackbird
Aug 15, 2021 10:16 PM
InfinityShade
Aug 22, 2015 08:00 PM
EFR2000
Aug 18, 2015 08:54 PM
wayshegoes
Aug 17, 2015 12:00 PM
Sherpajames
Aug 7, 2015 06:56 PM
