harness over 100mph???
Old Jul 23, 2001 | 04:10 PM
camaro6spd's Avatar
one of my friends told me that you need a harness when you go over 100 in the 1/4 mile. Is this true, Most of us here go over 100 mph in the 1/4
Old Jul 23, 2001 | 04:17 PM
Chronos_Titan's Avatar
no
Old Jul 23, 2001 | 11:17 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
Harness, no.
Jockstrap, yes.
Some of those tech inspectors can get pretty brutal sometimes.
Old Jul 23, 2001 | 11:25 PM
Greg Kuhlmann's Avatar
Wouldnt the track officals let you know.
Old Jul 24, 2001 | 03:14 AM
91z4me's Avatar
What about times I thought after your car was fast enough to run certain times you had to have a cage. But I never heard of a harness.
91 z-28 305 700R4
3.73 gears out back
T-Tops and Black all over.
Old Jul 24, 2001 | 07:21 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
5 point harness is required at 11.99 and quicker. 12.0 and slower only require a factory belt.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jul 24, 2001 | 10:55 AM
ATOMonkey's Avatar
Helmets are required to run 12's, over 200 mph you need a chute, 11's you need a cage, and if you already have a cage you have to run 5 point.
'89 Red Formula 350- 350 .060 over forged pistons 232* @ .020 cam Performer RPM Holley 750 DP Vortec 1.94 1.50 Accel Coil and dist. Hedman shorty headers Dual Exhaust w/ cutouts 1LE WS6 suspension, wheels, and brakes, 9 Bolt 3.27 Posi Edelbrock LCA's & Track bar subframe connectors 700R4 Harwood snorkel scoop Eclipse Head Unit Delco Bose Speakers 2 12" Pioneer subs w/ 400 watt/chanel amp
Old Jul 24, 2001 | 11:09 AM
91z4me's Avatar
Good to know but my car will never hit 11's. I would have to hook it up to a rocket to get it to go that fast.
91 z-28 305 700R4
3.73 gears out back
Old Jul 24, 2001 | 08:11 PM
AlkyIROC's Avatar
Car: 87 IROC L98
ATO: What rules are you looking at?
NHRA rules state that helmets are required at 13.99 and quicker. Most tracks want you to wear a helmet at all speeds.
A parachute is required for any car running 150MPH or quicker but it doesn't have to be deployed.
10.0 to 11.99 you only need a 6 (minimum 5) point bar if the floor or firewall are unmodified. If either are modified then a roll bar is only good to 11.0 and a full cage is required if quicker.
A car running 12.00 and slower can have a roll bar to add stiffness to the car but can still use the factory seat belts if they want. Since you need a roll bar once you hit 11's, a 5 point harness also become manditory.
Buy a rulebook. Don't quote rules without proper specs.
If you dip into the 11's, you'll also need a single layer fire jacket SFI 3.2A/1
Best 60 foot: 1.546
KO1
16
Oct 15, 2015 05:00 PM
92firebirdchris
Exterior Parts Wanted
Oct 1, 2015 01:38 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
z28joe2
Sep 28, 2015 05:54 PM
Eric-86sc
Sep 28, 2015 11:37 AM
