distributor question
Old Mar 31, 2005 | 08:41 PM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
I'm building a 350 for my 84 Trans Am, to be emissions legal and retain all of the computer controls. I'm thinking the stock 180,xxx+ mile distributor isn't a good idea on a fresh engine. can I get away with replacing the distributor gear, cap, rotor, coil and module etc on the stock one? Or are there any other aftermarket options that will work? Thanks for any help.
Old Mar 31, 2005 | 08:49 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
Actually, the HEI is about as dependable as an anvil, they just don't break. When it's out check the shaft to see if there is any side to side motion which would indicate the bushings are worn out. If they are, then it' s probably time to step up for a new diz. (up and down is usually no big deal, but if you feel like it you can purchase bushings to take out that play) If not, then pop the rotor off and check to see that the wiring isn't frayed or damaged. If that's OK, then there are a couple of aftermarket upgrades available, but you're limited due to the emissions laws so be careful.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
beastin91rs
Oct 9, 2015 07:38 AM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
