Another Help my car wont start post
Old Apr 2, 2005 | 07:30 AM
XChris1632X's Avatar
Car: 83 Z-28
Engine: LG4 305
i took my car out the other day because i finally had good weather. it ran pretty good and i did some maintnance to her and like everyone does i started to rag on it. well eventually i stoped and saw some people i knew that convinced me to do some burn outs. with my 295s on the back the car never wants to let go but i made it and the car started bouncing bad. when i stoped i started to hear a knocking noise but i think it is coming from my loose power steering pump. the problem is now when i shut the car off to check things it wouldnt start back up. i had my buddy push start me and it ran fine except for the noise. so i limped home to diagnose the problem and was looking around and had to shut the car off to adjust the power steering pump. well again it wont start. the battery is fine. although my choke light has been coming on lately but just flashing here and there. the car wont even turn over. it feels like it is a clutch sensor or something. considering how much of a shock my driveline just recieved and the fact that my clutch seems like it may be starting to act up this was all i could come up with. maybe it isnt disenganging enough or something. sorry for the long post
Old Apr 3, 2005 | 05:03 PM
Car: 83 Z-28
Engine: LG4 305
well i got it to start today with a little playing with that assembly the clutch connects too. there is a plastic piece that touches another when the clutch is pressed and i believe it was not connecting. i think this is what was keeping the car from starting. is this a common problem. well all in all i guess it really doesnt matter because after i took the car out a fox body 5.0 decided he wanted to play and after i started to go i went to shift into second and my trans just blew. no more second gear. So i guess a t-56 is in the works. i knew it would happen eventually but i didnt expect it now.
Old Apr 3, 2005 | 08:22 PM
jokers's Avatar
Car: 86firebird/86 trans am
Engine: 2.8ho/305HO 4BB
Transmission: WC T-5/700R4
your problem
that is your neutral safety switch. won't start unless it's pushed in and makes contact. it's there so you can't start the car without depressing the cluch.
Old Apr 3, 2005 | 09:17 PM
Car: 83 Z-28
Engine: LG4 305
yeah i figured that it was keeping the car from starting. i think it just needed a little adjustment. im glad i found out what it was incase it happens anymore but now i have to worry more about a new tranny.
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
