ECM Fuse
Old Jul 27, 2001 | 01:03 PM
Z28Man's Avatar
ECM Fuse
Where is the ECM fuse and what does it look like? I know it's near the battery, but there are a couple of fueses there. I am sick of losing my station presets! Thanks!
1988 IROC 350
Vette heads, SLP headers/Y-pipe,No EGR.
Old Jul 27, 2001 | 02:37 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Did you look in the fuse block?
Old Jul 27, 2001 | 06:12 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
You are correct, it's near the battery but that's the only fuse there. You might be confusing them with the fan relays. Anyway it's the only one with 2 wires going to it and it has a cap over the fuse.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Old Jul 27, 2001 | 07:08 PM
james_fearn's Avatar
The ECM fuse is by the small battery ground wire. The fuse itself is contained in a protective case that is held on the the inner pass. fender by a screw.
James
1985 Z-28, 350 TPI, T-Tops, edelbrock 6085 heads, ZZ4 cam, accel base/runners & 24 lb/hr inj., ported plenum, everything gasket matched, crane AFPR, SLP 1 5/8 headers, single 3" flowmaster catback, 3" Catco cat, modified tranny, 165 ECM & ARAP code, MSD 6AL/wires, edelbrock STB, Spohn SFC, GW "wonderbar"
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
