Swap TPI intake for an LT1 intake
Old Jul 26, 2001 | 09:20 PM
sportcoupe's Avatar
I have heard of people doing it and I have questions for them.
1. Do the ports line up? I understand I'll be drilling new mount holes.
2. Can I re-use my throttle body?
3. Will a small (1987+) diameter distributer clear? I understand I'll need to make the hole first.
4. Will running seperate coolant lines from each head (like circle track cars)to the radiator be sufficant?
Old Jul 26, 2001 | 11:16 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Won't work. Biggest problem is the LT1 does not have a place for a distributor. The LT1 uses Opti-Spark.
That is in spite of the fact that the LT1 intake requires LT1 heads which won't work on our cars either due to "reverse flow" and designed around the Gen II block.
Old Jul 27, 2001 | 03:45 AM
Tas's Avatar
Tas
LT1 intakes have been made to fit Gen 1 engines but the cost isn't worth it unless you have a machinest for a friend that will basicly do it all for you. The ports will like up but all the intake bolts are different as a preventative measure. You would need to make a hole for the distributor. You would need to make a water crossover passage in front under the TB where there isn't much, if any, room. John Moss put an LT1 intake on a green RWD late model Monte Carlo. They used a 400 small block chevy and use f-body floorpans to convert it to RWD. It was very cool. If you check out my EFI page, you will see a cheap intake from Holley. I also have an article on putting GenII LT1 heads on a GenI block. You can see the different intake bolt patterns and such. The L98 TB should fit a LT1 intake.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
[This message has been edited by Tas (edited July 27, 2001).]
Old Jul 27, 2001 | 05:25 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I have heard of people doing it before.
[This message has been edited by John Millican (edited July 27, 2001).]
Old Jul 27, 2001 | 05:51 AM
sportcoupe's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Tas:
LT1 intakes have been made to fit Gen 1 engines but the cost isn't worth it unless you have a machinest for a friend that will basicly do it all for you. </font>
I am a machinest on the side but not my primary job anymore, not enough money in it.
I was planning on filling(welding) the intake holes and re-drilling the intake to the TPI pattern so I won't have to touch my heads.
I too am concerned over the distributer, will a small base distributer clear if I provide the hole? that's simple to make that hole.
I guess I need to look for a used intake and look to see.
Old Jul 27, 2001 | 08:52 PM
sportcoupe's Avatar
This is why I'm asking. It has been done before and I want more information.
https://www.thirdgen.org/messgboard/...ML/002145.html
Old Jul 27, 2001 | 09:00 PM
iroc5speed's Avatar
I am just wondering what the benifits f the swap are. I don't really think that doing all that work to put the LT1 intake on would give you that much difference in power. The time and money are both better spent elsewhere. You could always just buy an LT1 engine and drop it in.
Old Jul 27, 2001 | 09:55 PM
sportcoupe's Avatar
<font face="Verdana, Arial" size="2">Originally posted by iroc5speed:
I am just wondering what the benifits f the swap are. I don't really think that doing all that work to put the LT1 intake on would give you that much difference in power. The time and money are both better spent elsewhere. You could always just buy an LT1 engine and drop it in. </font>
Benifits? How about higher rpm with more HP? Especially with a larger cube engine like a stroker motor. The alternate is the miniram and it's $1200-1500 depending on options needed. That's the motivation, cash.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
masonta
Aug 31, 2015 10:14 PM
sreZ28
Aug 14, 2015 07:48 PM
Sanjay
Aug 12, 2015 03:41 PM
