Comp Roller Cam.. What Distributor Gear?
Old Apr 4, 2005 | 12:02 PM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
So I bought a custom cam for my engine... It's a Comp Cams Custom Street Roller cam, Core 08-000-8.
Will I need to change distributor gears to run this cam or am I fine with my stock distrubutor gear?
What gear should I look for if my stock one won't work?
Old Apr 4, 2005 | 12:52 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
http://www.compcams.com/Technical/Cu...ML/224-228.asp
Looks like it's a cast core
Any factory distributor made since about 1981 has the right gear; the "melonized" one.
Old Apr 4, 2005 | 02:22 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The -8 in the cam code tells you.
-8. Street Roller hydraulic or solid. Will work with most standard distributor gears.
This means any factory or aftermarket distributor gear will work. Only when you get a billet cam will a bronze gear be required unless the billet cam has a cast gear pressed onto it.
Old Apr 4, 2005 | 02:26 PM
Thanks guys, so I now know I will be fine.
Just wanted to be sure.
junkcltr
Aug 2, 2019 11:12 PM
beastin91rs
Oct 9, 2015 07:38 AM
blackroc68
Sep 1, 2015 08:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
