im having intake manifold problems
Old Apr 5, 2005 | 05:38 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey guys,i have a weird problem going on with my car.i have a edelbrock perfomer manifold(dual plane)for my 87 up center
bolt heads.ive had for like 14 month never a problem.but
now my car boggs and misses ,like it backfires out the tbi.and they told that it my manifold that is bad?i said how can a manifold go bad if it has work perfect for thepast 14 months.so i need help to see u guys know wats my problem or if any has expierince it?
Old Apr 5, 2005 | 05:51 PM
brutalform's Avatar
Who are "they', that told you it was the manifold? Somtimes when an engine backfires through the carb, or T/B, it might have jumped time.
Old Apr 5, 2005 | 05:55 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
several people who have expirience the proble like tbichips.com and couple of extreme fi customers
Old Apr 5, 2005 | 06:00 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Your problem has nothing to do with your manifold. If it ran fine for 14 months logic alone should have told that the manifold was not the problem. Check your base timing. It sounds like the distributor bolt loosened up and your timing is all over the place. Your ECM will limp the car along even though the timing if off.
If it is not timing I would look into the fuel system.
Old Apr 5, 2005 | 08:05 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
i havent checked the timing yet,and fuel p is fineat idle but im gonna have to lift it and drive it so wat the fp does?
Old Apr 6, 2005 | 06:52 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
well my base timing is at 4* were i last left it.i read that some members problems was the pickup coil?wat exactly does it do?im gonna have to check fuel system carefully
Old Apr 20, 2005 | 08:29 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
well replace the whole disteibutor for a new and same problem
ASE doc
Alternative Port EFI Intakes
Jan 12, 2020 11:35 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
