Fuel Pump
Old Apr 6, 2005 | 09:41 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Fuel Pump
GM/Carter Street Performance fuel pump PN 12355612.
I'm on my second one of these in about three weeks. Both leak oil out through the top.
When the first one was returned the parts supplier said that he'd got another one back with the same problem. Seems to be seal inside which becomes displaced.
They were OK for about 75 mile and then they started to leak.
Does anyone know if there's a recognized problem with these things - like a bad productin run or something.
Mine had to be clocked to get it to fit but I don't think that's the problem.
Old Apr 6, 2005 | 09:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Is oil draining properly in your block?
Old Apr 6, 2005 | 09:49 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
It's a new motor - it should be draining properly? and there was a third pump returned with the same problem
Old Apr 8, 2005 | 07:24 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Does anyone know if indexing the pump will screw these things up?? As far as I know it shouldn't.
Old Apr 8, 2005 | 08:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There may be something wrong with your block. Oil in the fuel pump mounting area comes down from the cam around the fuel pump pushrod and usually drains into the pan quickly enough that there isn't usually enough oil in the area for all that much to accumulate in the pump. Where is it leaking from, exactly?
Old Apr 8, 2005 | 08:43 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
The vent hole. It's not leaking a lot but it is leaking.
Old Apr 8, 2005 | 09:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There isn't supposed to be enough oil in there for it to even be getting to the vent hole.
Old Apr 8, 2005 | 09:38 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Right. But there's a seal inside that was displaced on the first pump. Another was returned to the supplier with the same problem and I'm guessing we will find that this pump has a displaced seal as well.
However, the question of whether or not the block is draining properly is a good one. How do you test that?? apart from looking for the obvious obstruction of some sort.
Old Apr 8, 2005 | 10:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That would be about the only way I could think to do it.
Old Apr 8, 2005 | 10:21 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
I'm going to change this one again and if it doesn't work I'll try a Holly or something; if that doesn't work I'll drive the car into a wall at 120mph.
By the way, the wall around Toronto is almost completed and your associates in the West can start filling it with oil any time soon..lol
Old Apr 8, 2005 | 10:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Why waste perfectly good oil?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
