first time engine start up ?
Old Jul 30, 2001 | 01:41 AM
nelliesIroc's Avatar
I'm about ready to start up my 383 for the first time but I need to have an exhaust system bent up for it. I'm know that I will need to run it at 2,000rpm to break the cam in and I don't think the neighbors would like it too much if I ran it at 2 grand for 20 minutes in the driveway but I would just like to start it for a minute or two to make sure it runs before I haul it to the exhaust shop so my question is will I do any harm to the engine or cam by just running it for a short time at first?
Old Jul 30, 2001 | 05:59 AM
Pat Hall's Avatar
Just wanted to remind you that if you have a factory roller cam in your new engine, you won't need to run it at two grand for twenty minutes. The roller cams don't require a break in. However, if you are breaking in a flat tappet cam, as long as you have at least the exhaust manifolds or headers bolted up, it shouldn't hurt anything to run it for that long. You can risk burning an exhaust valve if you don't have at least those bolted up. As far as the neighbors go, they might get ticked off about the noise, but they'll get over it eventually! )
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Old Jul 30, 2001 | 07:05 AM
ede's Avatar
ede
why not get the mufflers done first? you will need to break in the engine reguardless of what type cam it has.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
86Base
Aug 8, 2015 01:34 PM
