Engine is running now but......
Old Apr 7, 2005 | 04:02 PM
Notplayn's Avatar
Car: Depends on the day!
Engine: the kind that runs on money
Transmission: One that holds up, I hope
Well I finally got the GTA running but I am having a problem with a couple of things. I am hoping that someone can point me in the correct direction. To start with I bought the car with a locked up engine. The kid that had it ran through some deep water and bent a rod or two and the car sat for a while. Fast forward--> pulled the engine and put a rebuilt 350 in it. Used the same TPI system. Car is running but it is hard to start cold, takes many cranks and then runs rough until it warms up. Once warm it idles ok but searches some and when I give it gas it falls on its face then picks up and accelerates good. I took the IAC apart and cleaned it. There was alot of rust on it and I am guessing could be damaged from the water that the engine swallowed. I put a brand new EGR valve on it but it has the same EGR solenoid. Could the solenoid be bad? I have set the TPS and the IAC. There are no codes stored. I have new plugs and wires and the timing is set correctly. Thanks... Once I get it running good I will post my very first burn out with it.
Old Apr 7, 2005 | 04:24 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds ALOT like unmetered air entering the intake behind the MAF somehow...
How is the PCV system hooked up? Is there one hose to one valve cover from one of the 2 places on the TB, and another hose from the other place going over to the PCV valve?
Old Apr 7, 2005 | 05:53 PM
Notplayn's Avatar
The PCV hose runs from the TB on the right side to the valve cover on the right side. The other hose on the right side of the TB runs to the canister. The left side PCV hose runs to the left of the intake manifold.
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
Caspar
Jun 19, 2016 11:19 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
