Dart Iron Eagle 180 heads
Old Apr 7, 2005 | 10:34 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Does anyone know what the Dart Iron Eagle 180 heads with 2.02 and 1.6 valves flow? Do they at least flow better than vortecs?I can pick up a set for $700 and I am wondering if they are worth it. I am looking to put it in a 350 with an XE268 cam, RPM air gap intake, and a 650 dp carb.
Old Apr 7, 2005 | 11:05 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
here is the flow of the dart heads if i was you i would use the vortec's they flow about 30 more cfm at .500 but the dart heads have a bout 15 more cfm exh but i would still go with the vortecs it would be alot cheaper.
Old Apr 7, 2005 | 11:06 PM
Car: 1987 iroc z
heres the vortecs
Old Apr 7, 2005 | 11:14 PM
11 Flat's Avatar
I E
.200 139/114 82.01%
.300 190/145 76.32%
.400 218/164 75.23%
.500 222/172 77.48%
.600 218/174 79.82%
Old Apr 9, 2005 | 12:36 AM
IROCaholic's Avatar
Car: 89 Camaro RS
Wow those numbers suck for the price. My 416's flow 210@.500 on the intake. And I paid $400 total for them. Holy crap. Well can anyone suggest a good set of heads for under $1000 that flow around 230@.500 other than vortecs, because if I get the vortecs I have to get all the special stuff for them and I dont want to, I already have the intake and rockers I want on my motor now. And the total kit is like $950. Thanks for the info guys.
Old Apr 9, 2005 | 01:47 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Tad over $1,000:
http://store.summitracing.com/defaul...8&autoview=sku
Little under $1000:
http://store.summitracing.com/defaul...0&autoview=sku
Old Apr 9, 2005 | 02:17 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Where did those Dart 3's come from. Because those are freakin ****ty then ****. Those #'s are no better than stock.
Old Apr 9, 2005 | 03:38 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Thanks for the link, but I already looked into both these heads and they are both great sets, but the sportsmans are 72cc combustion chambers which will make my compression like 8:5:1 and the trick flows are 62cc which will give me about 9:3:1 and with aluminum heads that sucks. I am actually looking at trick flows 305 heads now:http://store.summitracing.com/defaul...=egnsearch.asp
In another post I saw that they flow 240@.500 and the 58cc chambers will give me about 10:1 compression.
Old Apr 9, 2005 | 04:12 PM
pasky's Avatar
You could always try to run a different gasket.
Old Apr 9, 2005 | 04:51 PM
IROCaholic's Avatar
Car: 89 Camaro RS
I dont think they make a gasket thin enough to give me a jump from 9:3:1 to 10:1 if they do please someone let me know.
Old Apr 9, 2005 | 05:11 PM
pasky's Avatar
http://www.cometic.com/
They make custom gaskets, believe they go as low as .027. Not sure on what size piston your running. But yea, its probably not worth the trouble unless you buy some new pistons. You can get a set of sealed power forged pistons for $267. With 58cc heads should put you right at 10.4:1
Old Apr 9, 2005 | 05:31 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
dude where do u get forged pistons dat cheap. please gimme a link. i suck at findin stuff.
Old Apr 9, 2005 | 07:23 PM
pasky's Avatar
http://store.summitracing.com/defaul...3&autoview=sku
29.95 * 8 = 239.6 + 10 shipping = 249.6 shipped
Im personally running these for 11.54:1 compression:
And these are quality pistons. Their entry level forged but still damn strong.
Make sure you get the proper bore size.
Old Apr 10, 2005 | 05:04 PM
Krazzycowgirl's Avatar
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
Here is a bunch of comparing of heads.
http://www.carcraft.com/techarticles/41598/index4.html
Remeber the Iron Eagles you can get in CI or Alm.
Chuck84TA
Jul 15, 2016 09:05 PM
C409
Sep 23, 2015 04:30 PM
gixxer92
Sep 1, 2015 04:32 PM
theurge
Aug 21, 2015 12:46 PM
