Question on Intake Manifold
Old Jul 27, 2001 | 09:17 PM
84TransAm's Avatar
Will a Performer RPM fit under a stock Firebird hood with a drop base air cleaner??
--Steve S--
1984 Trans Am, Goodwrench 350, TES Headers, Performer Intake, Flowmaster 80 Series, Holley 600 cfm & vacuum advance, and T5 with short shift
Old Jul 27, 2001 | 10:25 PM
TransAm383's Avatar
If it helps,on my 84 TA I used a Performer RPM with Edelbrock 600 cfm Performer carb with a 10 inch Edelbrock open element air cleaner. I don't know if it was drop base or not, but the air cleaner stud was way taller than it had to be and I had no problems at all.
Old Jul 29, 2001 | 07:22 PM
Cosmik Debris's Avatar
If you have the power bulge hood on the 84 you will be fine. I have an RPM, Holley 600 and a 3/4" nitrous plate. I have a drop base aircleaner. It just fits.
Old Jul 29, 2001 | 08:54 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yea Im running the stock manifold + adapter plate "taller than a performer" with a 14x3 drop base no problems. The 10x2in edelbrock mentioned above actually sits higher than the 14x3 drop so I wouldent reccomed it.
SSC
Old Jul 29, 2001 | 09:45 PM
iroc5speed's Avatar
just 2 days ago I put a performer rpm on my camaro and I have an edelbrock 600 cfm carb and a 14" drop base air cleaner and it fits under the stock hood.
Old Jul 30, 2001 | 03:32 PM
84TransAm's Avatar
Good to know it will fit!! Thanks for the responses. For those of you that added the RPM, was it on the stock engine? and if so, how much of a difference did it make (this is going on my 350, but i'm still curious)
Old Jul 31, 2001 | 12:39 AM
iroc5speed's Avatar
my engine seems a bot quicker on the stock 305, especially at higher rpms. though I'm sure there will be quite a bit of differece once I've done more modifications.
ASE doc
Alternative Port EFI Intakes
Jan 12, 2020 11:35 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
