super ram install tips
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
what are the torque specs for the plenum lid bolts, the plenum runner bolts and the runner manifold bolts?
-also, is there a way to download the SR install directions anywhere? well...i guess all i really need is the bolt specs.
-also, I tried to take off my plenum lid, but after i took the bolts out, it was stuck. What do you think the best way to do this is...thanks?
Car: 89 IROC-Z
Engine: 383
I don't remember there being torque specs in the directions when I got mine....just go hand tight and not much more because those suckers strip out easy. Use Never Seize on the runner bolts as well. For the lid, try hitting the plenum with a rubber mallet or using a screwdriver to pry it up from the backside without trashing the metal.
Car: 1987 GTA
yeah, i kinda tried that already, but it's on pretty good.
ambainb
Apr 25, 2016 09:21 PM
