Oil pans?
Old Apr 11, 2005 | 06:40 PM
benscool1's Avatar
Car: 1985 Berlinetta
Engine: Carbed 305
Transmission: Built 700r4
Oil pans?
I have a 4 bolt main 350 out of a 78 Silverado that I am going to be putting in my 88 camaro because the 305 TBI started knocking. I want to get a set of 083 heads to put on, but I plan on using the stock intake and TBI, but I may need bigger injectors, I'm new to 3rd gen camaros so maybe you should tell me.
Anyway, will I be able to use the stock oil pan from the 350, or will I need to get an aftermarket one due to clearance? It may seem like a stupid question but I'm not sure. I'm used to working on trucks.
Old Apr 11, 2005 | 06:45 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The truck's pan will not fit the Camaro chassis.
The stock pan off your 305 will not fit the truck block.
You will need another pan. Doesn't have to be aftermarket if we can figure out what you've got.
Does the truck have a pass side oil dipstick, or a driver's side one? If driver's side, is it in between the #5 & #7 plugs; or is it toward the front?
Old Apr 11, 2005 | 07:46 PM
benscool1's Avatar
Engine: Carbed 305
drivers side dipstick between the 5 and 7 cylinders...
Old Apr 11, 2005 | 08:46 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
If you want a stock pan, the Summit cheapie unpainted pan fit my 400 in my 83Z. It not only fit, but had clearance for my TES Y-pipe too.
If you want a fancier oil pan, watch which one you get if you run Y-pipes.
BDR
Nov 7, 2015 03:05 PM
project89
Sep 22, 2015 09:35 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
