Intake Manifold and Valve Cover Gaskets
Old Apr 11, 2005 | 10:40 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Recently had an oil pan replaced and the mechanic told me the valve cover and intake manifold gaskets are going.Its a 3.1 motor and will probably cost a few hundred.Is it really anything serious to worry about? I'll eventully do them but I want to know how much time I have.What happens with these bad gaskets?
Old Apr 11, 2005 | 10:44 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'll chime in since I replaced my intake manifold gaskets a few days ago... I started leaking coolant like a sieve... other bad things are you could get a vacuum leak... either way it's something you'd notice...
valve cover? oil leaking a lot. I think that's it.
3.1L... injected.... don't think that changes much.... oh, probably no coolant in the intake manifold?
I've never head of gaskets *going*.... usually they're just gone.
Old Apr 11, 2005 | 11:25 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
3.1s go through intake gaskets like a fat kid through cupcakes. If you dont replace it, your cooling system wont hold pressure, your engine wont cool properly, you'll leak out all your coolant and eventually overheat the motor. Fix them ASAP.
Old Apr 11, 2005 | 11:32 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
OK, I give. How do you tell gaskets are going bad? They are aging just like everything else. They are either sealing or they're not. If it aint broke, dont fix it (unless of course your'e modifying it for more HP).
Old Apr 12, 2005 | 11:03 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Well, if you have a fluid leak thats a pretty good indiction that they aren't doing their job.
Old Apr 12, 2005 | 01:33 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
I agree but, the original post doesnt say anything about leaking. Like I said, if they are sealing then they are good ("sealing" should be interpreted as no leaks).
g.l.mos
Aug 22, 2015 12:02 AM
1985chevydude
Aug 20, 2015 12:29 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Jake_92RS
Aug 11, 2015 10:39 AM
