Funny Gas Tank Poblem
Old Apr 13, 2005 | 06:44 AM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
I have a 91 RS TBI, and my car has this funny problem with the gas tank. Whenever I brake hard, I find that my tank will drop about 1/2 (on the gauge), and if im at a 1/2, it will actually run out of gas. Is this a normal problem? Does anyone else have this problem? Also, is there any way around it or to fix it? (its kinda annoying) Any help would be greatly appreciated.
Thank you for your time.
-Tim-
Old Apr 13, 2005 | 07:34 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
I would verify it is really at half a tank by checking your mileage. The tank is about 16.5 gallons, so check your mileage to see what it is, then fill up and see how far you've gone when you run out to see if it is really at 1/2 a tank or if your sender is screwed up.
If it is at about a 1/2 tank, then it could be the rubber hose in the tank that couples the fuel pump outlet to the sending unit is split, or some other problem that would require dropping the tank.
Old Apr 13, 2005 | 06:29 PM
Car: 1991 Camaro RS
Engine: L98 350 TPI
i know that my gauge is correct because when i fill up from a 1/4 tank to full it is 12 gallons, so the sender is ok.
What should i look for when i drop my tank? (i plan on doin the 4th gen gas tank swap, so would this be the time to do it?)
thanks again
-Tim-
Old Apr 14, 2005 | 02:53 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
The way the tank is shaped and the location of the sender it is normal for the gas gauge to move some when stopping and going around corners.
Its not normal for it to run out of gas though. Its sounds like a baffle in the tank that keeps gas around the fuel pump has broke loose inside the gas tank.
The only way to find out is to drop the tank and look inside.
Old Apr 14, 2005 | 07:30 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I'd get fuel starvation and the motor would die if I have less then 1/2 tank and brake really hard. This only happened on late weekend nights at industrial parks braking from 90 to 0.
Old Apr 14, 2005 | 09:04 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
The top side of the gas tank is horizontal to the road surface, the side facing the front slopes down from front to rear, this minimizes stop/start sloshing. There's a piece of sheetmetal that splits the tank from front to back a few inches from the driver's side of the sending unit/pump opening. It anchor's the filler neck close to the bottom of tank, and acts a side to side baffle.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Bohemian
Aug 15, 2017 05:11 PM
amcnellis
Sep 16, 2015 04:16 PM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
