freeze plug maybe?
Old Apr 14, 2005 | 12:57 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
freeze plug maybe?
when i changed my oil today, i noticed a small puddle of antifreeze on the ground. i traced it to the rear of the engine where the oil pan meets the transmission. it's only dripping once every minute or two. do you think that this is the freeze plug, or something else? how safe is it to drive?
P.S. its a 88 firebird w/ a 2.8 mpfi and auto trans.
Old Apr 14, 2005 | 01:57 PM
84 Restore's Avatar
Car: 1984 Z28 camaro HO Gun metal Gray
Engine: 305,L69 H.O. rebuilt
Did you search up the back of the motor? I know its not easy mirrors work well. It might be a frost plug but it might be a leaking intake or head gasket hope you find it.
Old Apr 14, 2005 | 11:57 PM
eagle_eyes's Avatar
Engine: '93 LT1
no i haven't looked anywhere yet. i just noticed it today and didn't have time to pinpoint the location. i heard something about pressure testing. who does it and what does it do?
Old Apr 15, 2005 | 12:01 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Most mechanics will have a pressure test kit. They replace the radiator cap with an air pump and pressurize the system to see if it holds pressure, and if not where it leaks.
Old Apr 15, 2005 | 08:08 AM
eagle_eyes's Avatar
Engine: '93 LT1
thanks for the info. i guess it's time to go to the shop for a little bit, just to make sure i know where it's comming from.
Old Apr 19, 2005 | 12:30 PM
eagle_eyes's Avatar
Engine: '93 LT1
btw, how many plugs are there on the engine?
Old Apr 20, 2005 | 11:59 AM
eagle_eyes's Avatar
Engine: '93 LT1
anyone?
Old Apr 20, 2005 | 02:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Coolant plugs? About 4 or 6 freeze plugs and a couple of pipe plugs.
Old Apr 24, 2005 | 10:11 PM
eagle_eyes's Avatar
Engine: '93 LT1
well, today i pulled the drive shaft out, took the tranny out, removed the flywheel, just to replace the freeze plug that was leaking. i went ahead and replaced the others while i was there. i put the tranny back in and everything, now i just need the driveshaft. i'm replacing the u-joints while i have it out. the problem is that the u-joints that are on there are the origional ones and arent budging. any tips on how to get those out?
Old Apr 24, 2005 | 11:04 PM
sellmanb's Avatar
Car: '86 Berlinetta
a Big F*cking Hammer
No seriously, I had to take a hammer to mine, they were like welded in or something. If you're replacing the U-joints anyways, what's it going to hurt heh. Just give them a few good swift whacks and it should fall right out
Old Apr 25, 2005 | 01:20 PM
eagle_eyes's Avatar
Engine: '93 LT1
lol
i tried that a little...i didn't go overboard or anything though. thanks for the tip.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
Stryker412
Sep 20, 2015 06:59 PM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
